removing immobilzers
Old May 19, 2004 | 12:25 PM
shadykit's Avatar
Default removing immobilzers
what happens when you remove immobilzers on the 99 GSR ECU?
What does that do?
Old May 19, 2004 | 03:51 PM
Katman's Avatar
Default Re: removing immobilzers (kitchale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitchale &raquo;</TD></TR><TR><TD CLASS="quote">what happens when you remove immobilzers on the 99 GSR ECU?
What does that do?</TD></TR></TABLE>
There's 1 downside & 1 goodside.
Down side:
you will have a constant check engine light on whatever OBD2 vehicle you use the ecu in, but it will NOT be in limp mode.
Good side:
The ecu will work in any OBD2b vehicle you use it in vs. NOT working at all in any vehicle (except for the one it originally came in) when the IMM is intact.
Side note: When using a 00-01 integra ecu w/removed immobilizer in a civic, pinout A16 needs to be moved to A15 or else the car won't start.
Also...
When the IMM is removed, there's a slight trick you need to do when starting the vehicle. Turn the cars ignition on 2 clicks, wait for the fuel pump to "humm" on then off, then turn the key a 3rd click turning the car on. If you try and start the car without doing it this way, the car may not start up right away, it'll just crank & crank & crank.
Old May 19, 2004 | 05:57 PM
VTECorona's Avatar
You should have no problem stealing integra's now.
Old May 20, 2004 | 11:39 AM
Joseph Davis's Avatar
Default Re: removing immobilzers (VTECorona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">You should have no problem stealing integra's now. </TD></TR></TABLE>
IMM removal has absolutely nothing to do with vehicle theft. Unbolting the ECU, popping the cover, and sidecuttering out the IMM board at 4am when it's pitch black sounds pretty clumsy and stupid to me.
Cheap OBD jumper harnesses and freeware ECU tuners, however, definitely contribute to vehicle theft. Lynch pgmfi.org! Down with boomslang.com!
While we're at it, time to start pogroms against Jerr-Dan for performing roll-back conversions on heavy duty pickups, and witchhunts among your local wrecker services.
Old May 20, 2004 | 11:44 AM
blundar's Avatar
Default Re: removing immobilzers (J. Davis)
every fast honda that I've ever heard of getting stolen around here was flatbedded. enough said.
Cimburke23
14
Nov 18, 2013 03:18 AM
anthonyelevenEX
Engine Management and Tuning
Sep 3, 2010 08:24 PM
SirRevvs
Feb 19, 2007 02:51 PM
KooK
Feb 20, 2006 10:34 AM
integra-modder
Jan 7, 2004 07:07 PM
