D16 clutch desicions
Old May 19, 2004 | 11:48 AM
kabaroo's Avatar
Default D16 clutch desicions
I did search but im looking for more personal info.
Im looking for a new clutch and flywheel for my del sol. I daily drive my car but my stock clutch is slipping a bit, im having trouble chirping 2nd.
my setup: d16z6, boosted at 6psi, 2-1/2 exhaust. Also i think i will be hondata tuned for 9-10 psi at the end of the summer or next spring. So i want the clutch to be able to handle that.
These are the clutches im looking at:
1. ACT Performance Organic Street Disc - with the streetlite or prolite flywheel.
2. Exedy organic clutch - with exedy flywheel.
3. Suggestions? please ! Will the clutches above hold the mighy tq #'s ill be making?
i would like to spend around $500 on the clutch and flywheel. My birthday is coming up soon so this would be a great present.
Thanks!
Old May 19, 2004 | 12:54 PM
Chiovnidca's Avatar
Default Re: D16 clutch desicions (kabaroo)
I had an Exedy cerametalic on mine. It held 12 psi and was great at the track. But it chatters a little too, makes driving in traffic a pain. I put a stock clutch back in and it breaks loose under full boost. I'm interested to hear how the orgainic clutches perform.
Old May 19, 2004 | 01:36 PM
Daniel's Avatar
I used to have the GReddy kit at 5-10 psi--depending on if my HKS VBC decided to work or not --and I ran the ACT HDSS kit on my Y8. It worked great! Pedal feel is a bit stiffer than stock, but I used it in stop-and-go traffic without a problem. It also held the power just fine; ACT rates it at 223 lb-ft of torque, which should be good enough for 10 pounds. I still use it even though I'm no longer boosted, and it's still going strong. It has about 13000-14000 miles on it. 10500 of those were boosted.
Old May 19, 2004 | 01:38 PM
kabaroo's Avatar
Default Re: D16 clutch desicions (Daniel)
Good, i think im leaning toward the ACT HDSS but im unsure about the flywheel... prolite or streetlite? HELP!
Anyone else have any imput?
Old May 19, 2004 | 02:28 PM
evosol's Avatar
before you buy make sure to look into Clutch Specialties clutches! ive had mine for about 6 months now and am very happy with it. I got the 6 puck unsprung with heavy duty disc... My personal opinion is... its still very streetable and the pedal is just alittle stiffer than stock. if you go to the classifieds section in Homemadeturbo.com forum and look at the sticky up top the member name is 88 turbo crx or something like that...i got mine 250 shipped.
Old May 19, 2004 | 03:44 PM
Mini-mEK4's Avatar
Default Re: D16 clutch desicions (evosol)
i have an action six puck sprung clutch on mine and i like it for the most part. it seems to come with a stock pressure plate or something because the pedal feels real soft, it grabs nice tho.
Old May 19, 2004 | 03:48 PM
RCautoworks's Avatar
Default Re: D16 clutch desicions (Mini-mEK4)
ACT
Old May 19, 2004 | 04:01 PM
kabaroo's Avatar
Default Re: D16 clutch desicions (90blackcrx)
im still leaning toward ACT. i dont want anything cheap or i dont wanna take any chances. i do things the right way, the 1st time.... usually haha
Thanks, keep the suggestions coming!
Old May 19, 2004 | 07:31 PM
kabaroo's Avatar
up!
Old May 19, 2004 | 07:37 PM
nocturnaldragon's Avatar
Im running the Act, HDSS works GREAT!
Old May 19, 2004 | 07:42 PM
The Internet Tough Guy's Avatar
Default Re: D16 clutch desicions (nocternaldragon)
act hdss w/ prolite fly here ... love it to death. come to pittsburgh and drive my car, you'll be sold on the prolite i promise. if you're getting a light flywheel, at least get a light one.
Old May 19, 2004 | 07:49 PM
XxSOHCDriVerxX's Avatar
Default Re: D16 clutch desicions (jwn7)
i have a ACT stage 2 clutch with a Exedy pressure plate on my little D16. best mod ive done so far. didnt know the value of a aftermarket clutch until i bought the ACT.
Old May 19, 2004 | 07:53 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: D16 clutch desicions (XxSOHCDriVerxX)
ACT HDSS
Old May 19, 2004 | 07:59 PM
duh blacksheep's Avatar
i have the HDSS and prolite on my greddy turboed d16. the pedal feel is like stock. this setup is so easy to drive that i regret not getting the 4 puck disk.
since the pedal is so light, feathering a puck disc is no biggy for an average driver.
If you want a setup that chirps, keep your stock flywheel.
also, tq ratings on a clutch is static friction. from gear to gear, it will be moving, so always get something more than your car can put out.
Modified by duh blacksheep at 7:19 AM 5/20/2004
Old May 19, 2004 | 08:33 PM
blackeg's Avatar
Default Re: D16 clutch desicions (duh blacksheep)
definately do hdss. i have been running that setup naturally aspirated with a streetlite flywheel since the end of last summer and i love it. ill see how it feels with boost soon enough
Old May 19, 2004 | 08:52 PM
kabaroo's Avatar
Default Re: D16 clutch desicions (blackeg)
Thanks guys, ACT HDSS it is. im still tore on the flywheel tho. my racing instinct says go prolite but something else says streetlite. But then again i got that same feeling when i bought race springs over sport springs...
i guess prolite flywheel? anyone gunna change my mind?
Old May 19, 2004 | 09:16 PM
when i got mine, it was great...now i wish it was lighter, get the idea?
HDSS is so streetable, i bet you're gonna wish you went with a puck disk, oh btw is cheaper, lighter, and holds more torque
what does it mean that you got your blue box tuned?
Old May 19, 2004 | 09:50 PM
you're right about the flywheel, but wrong about the clutch.
always use the least agressive clutch that can do the job - anything more is unnecessary, and just puts shock on your tranny. if you're boosting 10 psi the hdss will hold up fine; however, you might want to go for the xtss as it's the next step up. try contacting act and see what they would recommend.
but yeah, a light flywheel is nothing but great. anybody who says otherwise either: a) has never used one or b) needs to convert to auto. 8.8lb prolite, 6.75lb comptech or ... 6.1 lb tilton
Old May 20, 2004 | 07:10 AM
kabaroo's Avatar
thanks you all once again.
When i say blue box tuned its a joke. Ya know the fuel management in old greddy kits...
Old May 20, 2004 | 08:41 AM
RyanEJ8's Avatar
I used the ACT Street Disk and HDSS Pressure plate, it held up good to 210 ft lbs of torque so far. I'm going to try pushing it a little farther now, but may have to end up upgrading to a 4 or 6 puck and Xtreme Pressure Plate.
Old May 20, 2004 | 09:20 AM
evosol's Avatar
keep your options open...
just b/c it comes with a cheaper price than act doesn't mean your comprimising quality. do a search , ive never heard anyone having a problem with them.
https://honda-tech.com/zerothread?id=582632
https://honda-tech.com/zerothread?id=299819
https://honda-tech.com/zerothread?id=469040
Old May 20, 2004 | 10:43 AM
kabaroo's Avatar
Now i need to find a good place to buy ACT HDSS and a prolite flywheel... anyone on HT sell them?
Where the deals at!?
Old May 20, 2004 | 10:31 PM
kabaroo's Avatar
up
Old May 20, 2004 | 10:55 PM
trooper0641's Avatar
i have the stock exedy complete clutch kit w/ the act prolite flywheel and my pedal is too light. And I dont know why...maybe its my flywheel? What the hell!
Old May 20, 2004 | 11:06 PM
Default Re: D16 clutch desicions (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">i have the stock exedy complete clutch kit</TD></TR></TABLE>
because your pressure plate has the same clamping force as a stock one.
duh
