GSR Girdle with B20 block
Old May 19, 2004 | 09:33 AM
fabshybrid's Avatar
Default GSR Girdle with B20 block
i was thinking of using the gsr girdle with a b20 block. will this work, i have heard of people using it, but i also heard that the crank has to be workeed on. if any body has any info. please tell me. any links will help out.
thanks
Old May 19, 2004 | 01:38 PM
BigBodySmith's Avatar
Default Re: GSR Girdle with B20 block (fabshybrid)
not really sure if the crank has to be worked on, but i know the girdle has to be machined a little. you will also need a gsr windage tray to clear the girdle. the b20 windage tray will not clear the girdle. with that said, you also need a gsr oil pick up and oil pan. This is pretty much all i know, because i am doing the same thing to a b18b block.
Old May 19, 2004 | 05:08 PM
chad's Avatar
Moderator
yes it can be done...i have done it on 2 b20 blocks....
YOU MUST LINE BORE IF YOU DO THIS
i also used the gsr mains for 2-3-4 so that was the reason for line bore...
Old May 19, 2004 | 05:43 PM
turbociv's Avatar
also make sure to use dowels with it. Line bore is critical whether using gsr 2,3,4 mains or stock machined 2,3,4.
Old May 20, 2004 | 12:32 AM
MaxBoost's Avatar
New User
Default Re: (turbociv)
I just did a line bore, but w/o using the girdle..if I machine the gsr girdle to fit my ls caps, do i need to re-line bore? What if I use a z10, endyn, function 7, etc girldle?
Old May 23, 2004 | 08:24 PM
96MidoriHatch's Avatar
Default Re: (MaxBoost)
how important is it to use a block girdle? i have a b20 block with eagle rods and je pistons with a stock b16 head and i was planning on not using the block girdle unless someones convinces me other wise
Old May 27, 2004 | 09:42 AM
Yosshaa's Avatar
Default Re: (96MidoriHatch)
what exactly is a line bore? how much does it cost?
Old May 27, 2004 | 10:06 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote">I just did a line bore, but w/o using the girdle..if I machine the gsr girdle to fit my ls caps, do i need to re-line bore? What if I use a z10, endyn, function 7, etc girldle?</TD></TR></TABLE>
My understanding was that you could use a GSR girdle (machined to fit) and still utilize the B20 mains....can anyone confirm this?
Old May 27, 2004 | 10:26 AM
EF_LSVtec's Avatar
Default Re: (skunked)
you have to use the GSR mains with the girdle...reason for line-honing.
Old May 27, 2004 | 10:36 AM
skunked's Avatar
Default Re: (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">you have to use the GSR mains with the girdle...reason for line-honing. </TD></TR></TABLE>
I understand that. My question is below,
My understanding was that you could use a GSR girdle, machined to fit LS/B20 mains....can anyone confirm this?
Old May 27, 2004 | 10:39 AM
0bd1_Kanobe's Avatar
I would go with a GE girdle but that's just me but if you already have the gs-r machine it, I have one in stock with main's if you want it
Old May 27, 2004 | 10:44 AM
skunked's Avatar
Default Re: (BseriesHybrid)
I have a spare GSR block & girdle already. thanks though.
Old May 29, 2004 | 05:02 PM
what if you don't use the block girdle?
Old Jun 3, 2004 | 07:46 AM
I dont think it really makes a huge difference but as long as your clearence's are correct and within spec you dont need a girdle unless your going real crazy
Old Jun 25, 2004 | 04:36 PM
Touch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96MidoriHatch &raquo;</TD></TR><TR><TD CLASS="quote">how important is it to use a block girdle? i have a b20 block with eagle rods and je pistons with a stock b16 head and i was planning on not using the block girdle unless someones convinces me other wise</TD></TR></TABLE>
Can someone answer this question please?
Old Jun 26, 2004 | 01:41 AM
sittin on GOLD's Avatar
Default Re: (Touch)
Why dont you guys buy a Golden eagle girdle kit. it comes with pre machined dowels so its a TRUE bolt on ... not like Z10's. You do not need to machine or take to machine shop.. you can do this all at home. Too much hassle.. instead of buying a GSR girlde and gettng it line bored just by a Golden eagle. You can purchase them from Camp1320.com for about $200 brand new
Old Aug 7, 2004 | 09:27 PM
crxb20ed's Avatar
Default Re: (advertise)
I found out that the gsr girdle can be seperated from the gsr mains, the girdle has the dowels that fit the gsr mains, so this is the reason to have the b20 mains machine(or opened up some) at the main bolts to exept the girdle, this means you dont need to align bore it, plus, why take the chances of messing up a correct factory spec align bore just for the girdle that you wont even see much of a differece if you didnt even have it?, maybe on a sleeved b20 running crazy boost, might be a must for a girdle, I have had my crvtec running 3 different setups, have not seen the need for the girdle yet, though I am going to use it this time around, cheap inssurence
CW teg
Jun 24, 2010 10:51 AM
banditdog
Jul 9, 2008 04:43 PM
lakai_19
Mar 12, 2008 07:51 PM
civicswap
Mar 19, 2006 05:27 PM
