alignment q's
oK..just lowered the car on h&r sports...took it for an alignment..
they could only set toe-in..
here's my current measurementgs
Front
Camber L: -3.3 R: -2.3
Caster L: -1.6 R: -.7
Toe L: +.01 R:-.01 [from -1.12, and -.26
steer ahead is at .01 from -1.38
rear thrust is .07
will i notice significant wear with that camber? i'll put a kit on this summer, what kit do you reccomend?
basically..what do you think of the numbers
and..what is caster, steer ahead, and thrust angle?
sorry for being dumb
Front
rear thrust is .07
I would like to see the thrust angle closer to 0.
Unfortunataly -3.3 on the front left WILL wear those tires, no matter what the toe is. What the hell has that car hit, because that is NOT normal for the camber to be that bad on the front left, especially with just H&R Sport springs. Front right camber looks spot on for those springs.
