accord turbo, oil feed/return length???
ok, im bout to order some things, how long does the feed and return need to be for the ss oil lines for the turbo. 4 feet for feed from rear of block, and 1 foot for drain? im using all twist on fittings, no hoses and clamps... manni is generic log manni and f22b1 motor...
sorry no answer for ya, but let me know when you get it
- what manifold you using? I still need to get over to tally (isn't it?) and check out your ride.
depending on the manifold and positioning I would not think you would need that much.
I have about a 6-7 inch return and maybe a 3 foot feed and I have a bit extra slack on the feed (I used a oil adapter btw).
for the most accurate lengths, I would use a piece of wire or string to mock up the lines and measure the pieces.
damnit kenny i told u... 3.5-4ft for oil feed (go 4ft if ur unsure... better to have it longer than too short)
and the oil drain... test fit the manifold, turbo, and dp up and then use the wire to measure if u want.
i dont have the dp welded up yet... ive got a 2.5" pipe that i think i can just stick there for reference. tomorrow ima put the piping form the old accord on and hack up the bumper support too to fit the blingin front mount
I offer a compelte oil feed and return line kit for your accord with any kind of turbo.
I can guarantee that our pricing is lower than what you can piece it out for and no trips to hardware stores back and forth. All kits comes COMPLETE with everything that you need.
The oil feed line kit,
The oil return line kit,
You do need to have a threaded oil drain flange for the oil return kit, most turbos comes with it, if not, I can supply you with an aluminum billet flange and gasket.
There will be 15% break if you get everything, $ 119 shipped.
If you already have some of the parts and just need a few pieces to compelte it, let me know as well, I will help you as much as I can.
here's what our customers says about us (me
https://honda-tech.com/zerothread?id=819656
thanks again, I hope I can be some help to your puzzle
Stan
214-783-7247
Stan
214-783-7247
just a generic spoolin turbo manni
