camber kits??!!
Old May 18, 2004 | 05:20 PM
dethonhiway's Avatar
Default camber kits??!!
All right, i know it's a lame question but witch camber kit should get (brand name)
and how many deg. of adjustment do i neeed for 1.75" F and 1.5" R of drop? (neuspeed sport springs).
Old May 18, 2004 | 05:23 PM
frenchy's Avatar
Default Re: camber kits??!! (dethonhiway)
from the research ive done for that little of a drop you really dont need one, unless you plan on doing autox and then most people use the skunk2 uca replacement
Old May 18, 2004 | 05:33 PM
how low can i go before do need camber kits
Old May 18, 2004 | 05:34 PM
MrFast4Ward's Avatar
Default Re: camber kits??!! (frenchy)
I sell the same kit I have had on my car for months with no problem, made by REVO Technica.
Old May 18, 2004 | 05:42 PM
Sukebei Oni's Avatar
Default Re: camber kits??!! (MrFast4Ward)
i personally don't like the skunk2 design. looks too weak. i've seen them bend before from hard driving. i would go with comptech. and you can just add washers in the rear.
Old May 18, 2004 | 05:46 PM
Default Re: camber kits??!! (Sukebei Oni)
What about ingall's or eibach kits?
Old May 18, 2004 | 05:50 PM
the ingalls i saw looked pretty good too.
not sure about the eibachs
Old May 18, 2004 | 07:01 PM
dannylDAsport's Avatar
best thing is lower ur car first then get a alignment reading before deciding do u need a camber kit, most drop in a small car will make camber differents.
Old May 18, 2004 | 08:17 PM
LSeeper's Avatar
Default Re: camber kits??!! (dannylDAsport)
i dont think u even need a camber kit because your car is not that low, just get an alignment
Old May 18, 2004 | 08:27 PM
ragejed's Avatar
Default Re: camber kits??!! (LSeeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSeeper &raquo;</TD></TR><TR><TD CLASS="quote">i dont think u even need a camber kit because your car is not that low, just get an alignment </TD></TR></TABLE>
i put type r springs on my gsr. Stock shocks, and im negative camber, front and back. Its enough to wear the inner parts of my tires : /
Old May 18, 2004 | 09:14 PM
g2typeryellow's Avatar
3/4 of an inch of adjustment for every inch drop in the front and 1/2 inch of adjustment for every inch drop in the rear.
Old May 18, 2004 | 09:39 PM
mattbcool's Avatar
my cars camber was so bad after being lowered i couldnt even get it alligned without fixing the camber first
Old May 18, 2004 | 09:41 PM
Default Re: (mattbcool)
so then which kit should i get?
Old May 18, 2004 | 09:44 PM
MugenGTR's Avatar
Default Re: (dethonhiway)
https://honda-tech.com/zerothread?id=645818
i have hr sport with lower 1.75 f and 1.5 r but i think its more like 2 inch f and 1.75 after some wear. camber is off, but SORT of improves traction.
Old May 19, 2004 | 03:39 PM
ragejed's Avatar
Default Re: (MugenGTR)
I know the newer design of the skunk2 camber kit looks hot. Seems like they finally fixed all the issues. Where can I get this one? Or is there another camber kit for the front that is just as good? cheaper maybe?
How about the back? How do i do this washer trick? im lowered like .75 inch, stock type r springs. I need to order a camber kit now Last time i got an alighment, they camber was off. Months later, the inner parts of front and back tires wore down
Old May 19, 2004 | 03:42 PM
TrueUntilDeath.com's Avatar
Default Re: (ragejed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragejed &raquo;</TD></TR><TR><TD CLASS="quote">I know the newer design of the skunk2 camber kit looks hot. Seems like they finally fixed all the issues. Where can I get this one? Or is there another camber kit for the front that is just as good? cheaper maybe?
How about the back? How do i do this washer trick? im lowered like .75 inch, stock type r springs. I need to order a camber kit now Last time i got an alighment, they camber was off. Months later, the inner parts of front and back tires wore down</TD></TR></TABLE>
wow, w/ just a .75 drop? i have 1.75 and 1.5 and they are no signs of uneven wear..
the washer trick can be found on TI projects section
Old May 19, 2004 | 07:05 PM
quiksheit's Avatar
Default Re: (NA Integra)
go check out the articles at TI they show how to do the washer trick in the rear. Well if your drop even needs it that is
Old May 19, 2004 | 09:22 PM
Austin's Avatar
Take a look at this post for what I installed in the rear, and the part that I want to install in the front.
https://honda-tech.com/zerothread?id=864273
Austin
Old May 23, 2004 | 09:30 PM
Default Re: camber kits??!! (Austin)
for the rear you can just remove the two bolt that bolt the rear arm to the car and go buy longer ones. probably only need to be an inch or 3/4 of an inch longer then just add spacers that will take up the extra inch or 3/4. for the front you can buy anything the adjusts up to an inch and a half. i bought a cheap o off from ebay for 70 dollars shipped and it is the exact same as ingalls. the control arms are a little better and easier but pretty much the same thing.
fin781
Dec 27, 2011 04:18 AM
nfg177
Aug 13, 2006 09:35 PM
blk94gsr
Feb 11, 2006 07:23 PM
wildstallion
Aug 9, 2002 03:34 PM
vpforeva
Jun 2, 2001 10:58 PM
