DAMN TACH!!!
Old May 18, 2004 | 04:59 PM
WhiteEG6's Avatar
Default DAMN TACH!!!
I am having some problems with my distributor. Last week my tach started to jump back and forth the symptoms of a bad igniter, so I replace the igniter and the problem remains. While IM accelerating the tach moves slightly, but under WOT it pegs quickly to 8K. Could it be anything else that I have missed? I checked all my connections. I notice that when I turn the key to the acc spot the tach moves to 1k. IM stumped here.
Old May 18, 2004 | 05:18 PM
RZProStreet's Avatar
Default Re: DAMN TACH!!! (WhiteEG6)
Sounds like it might be a ground issue. Check the ground from the transmission to the frame and aslo the wire harness ground on the thermostat housing.
Old May 18, 2004 | 05:37 PM
NSTY Z33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteEG6 &raquo;</TD></TR><TR><TD CLASS="quote">I am having some problems with my distributor. Last week my tach started to jump back and forth the symptoms of a bad igniter, so I replace the igniter and the problem remains. While IM accelerating the tach moves slightly, but under WOT it pegs quickly to 8K. Could it be anything else that I have missed? I checked all my connections. I notice that when I turn the key to the acc spot the tach moves to 1k. IM stumped here. </TD></TR></TABLE>
Me too!!! Hahahaha!!!
I wish i can find out what it is to. Same thing happens here.
Old May 18, 2004 | 05:54 PM
WhiteEG6's Avatar
I was thinking to myself that it could be a ground but could never convince myself of it. Ill check it out. Ill keep you guys posted thanks
Old May 18, 2004 | 06:11 PM
pro1342's Avatar
Check the ground on the thermostat housing.....
Old May 19, 2004 | 09:55 AM
NSTY Z33's Avatar
Default Re: (WhiteEG6)
Let me know what it was if you fixed it and where to fix it.
Old May 19, 2004 | 12:12 PM
Adam.'s Avatar
Default Re: (JDMCRXDelSol)
i'm having the exact oppostie problem. My tach drops to zero. Anything?
Old May 19, 2004 | 09:50 PM
integg93's Avatar
Hey Bro i had the same problem so i opend up my distributor and checked all my terminal plugs that lead to the igniter and the coil some of them were worn down by the heat so i cut them off and replaced them and it works ok know but it would jump up to 8000rpms then back to 4 even if i waznt driving but its good to go now but try checking that..
Old May 20, 2004 | 03:57 AM
Adam.'s Avatar
Default Re: DAMN TACH!!! (integg93)
My Dizzy is brand new from the distributor king. Besides that, I've already swapped it out for a friends dizzy who doesn't have the problem ending up with the same result.
lexusgui
Jul 27, 2008 07:54 PM
soad1234
Aug 19, 2007 01:45 PM
crxb16ftw
Jun 20, 2007 12:02 PM
sit220
Jun 13, 2004 04:07 PM
WhiteEG6
May 25, 2004 09:51 AM
