96 cx.....mini me swap!!! please help me out a little bit!!!!
Hye guys ...l this research is for my friend.. he has a 96 civic cx and hes thinking about putting a vtec head on it and i have a couple questions ... and yes i did a search but i can norrow it down enough to my specific needs.... sooo ....
1. it would be easier to use a y8 head compared to a z6 head because the dizzy will bolt right up.. correct???
2. does he need the vtec dizzy or will his stock one be ok????
3. will his stock intake mani be ok or should he get a vtec intake mani???
4. what exact ecu whould he run in his car..
5. someone told me that vtec is electronicaly controlled and that u dont need to run an oil line... is this true???? i thought that u needed the oil pressure to engage the pin into the 3rd rocker???
6.. how many, and which wires need to be wired for vtec?(ill figure out where they go by looking at ecu pinouts)
please help me out guys ... i know some of you out there really know your **** so share the weath!!!!!
thanks
Joe
This might help... https://honda-tech.com/zerothread?id=554053
Hatchdude
Jun 30, 2005 01:37 PM
92hatchattack
May 19, 2004 03:11 PM
