clutch clip
Old May 18, 2004 | 11:23 AM
ekdriven's Avatar
Default clutch clip
i was wondering if anyone knew why when i push down the clutch it makes a little click noise and when i release the clutch it also makes the click noise its around when its halfway down. is my clutch goin?
Modified by deputyGSR at 8:34 PM 5/18/2004
Old May 18, 2004 | 11:34 AM
ekdriven's Avatar
i meant clutch clicks not clip sorry :x long day at work im jus out of it
Old May 18, 2004 | 11:36 AM
TrueUntilDeath.com's Avatar
Default Re: (deputyGSR)
search archives for *clutch click* i have had the same problem but it comes and goes.
Old May 18, 2004 | 11:55 AM
SuzukaBlueAP2's Avatar
Default Re: (NA Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA Integra &raquo;</TD></TR><TR><TD CLASS="quote">search archives for *clutch click* i have had the same problem but it comes and goes.</TD></TR></TABLE>
Wow, you've been here for a whole day and you already know that is in the archives? that'd be a first on here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deputyGSR &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if anyone knew why when i push down the clutch it makes a little click noise and when i release the clutch it also makes the click noise its around when its halfway down. is my clutch goin?
Modified by deputyGSR at 8:34 PM 5/18/2004</TD></TR></TABLE>
If you want to know if your clutch is going, start the car, put it in 3rd gear, and slowly let the clutch out. If the car stalls, your clutch is ok. if it doesn't, then the clutch is going to need changed.
I've heard of all kinds of clutches making different noises. I can't say that I have experienced them first hand though. The only one I have experience with is the Exedy clutches. Both of mine have squeeked when you depress the clutch pedal. I guess it's a common thing. I just deal with it.
imadigitalgod
11
Nov 18, 2006 11:27 PM
ic89
Oct 17, 2006 11:59 AM
oxSLEEPERxo
Mar 19, 2005 07:40 AM
AspectIndustries
Jan 5, 2004 07:49 AM
vtec-izm
Nov 23, 2003 09:22 AM
