alighning clutch?
Old May 18, 2004 | 08:32 AM
DubyaAye's Avatar
Default alighning clutch?
does anybody know wherre can i get the tool to alighn a clutch for the b series?
Old May 18, 2004 | 08:49 AM
kur0ryu's Avatar
Default Re: alighning clutch? (DubyaAye)
They usually come free with the new clutch kit, but I've had experience using a slide-hammer to align the clutch.
Old May 18, 2004 | 10:13 AM
DubyaAye's Avatar
Default Re: alighning clutch? (kur0ryu)
im puttng a used clutch in for a friend. so theres no way i can buy one. i tried calling honda and they say they dont have the tool even if you buy the clutch from them.
Old May 18, 2004 | 10:33 AM
4drGSRSLPR's Avatar
you can just use your eye!!!! ...... its very simple to align the disk with sheer vision. if you cant get it on right there are places every where that sell the universal alignment tool. they are on ebay too. http://cgi.ebay.com/ebaymotors...33730
Old May 18, 2004 | 10:35 AM
DubyaAye's Avatar
Default Re: alighning clutch? (4drGSRSLPR)
damn i need it by today. i just call my bro. up he said that i can try and get some piece from a broken b16 tranny i have. is that true.
Old May 18, 2004 | 12:02 PM
Revi's Avatar
AutoZone might rent them out.
Old May 18, 2004 | 12:26 PM
civickiller's Avatar
Default Re: alighning clutch? (Revi-Ra)
i bought this universal clutch alignment tool
Old May 18, 2004 | 12:44 PM
kur0ryu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye &raquo;</TD></TR><TR><TD CLASS="quote">damn i need it by today. i just call my bro. up he said that i can try and get some piece from a broken b16 tranny i have. is that true.</TD></TR></TABLE>
if you have drive shaft off the broken tranny that will work better than anything.
Old May 18, 2004 | 02:39 PM
EG_y0
Guest
Posts: n/a
buy one then return it sayign its not for your application
Old May 18, 2004 | 03:18 PM
Lord Helmet's Avatar
Default Re: (dub_c)
here's a site: for the clutch aligning tool
http://clutchcityonline.com/Me...8-026
$4.00
**** the powerbuilt pos made in taiwan ****
Modified by sleeperciv at 8:11 PM 5/22/2004
Old May 18, 2004 | 05:10 PM
99B16Si's Avatar
put the disc and flywheel on but down tighten them down all the way so the clutch disc can move around in between the pressure plate and flywheel. wobble the tranny on thereand make sure the spline gets thru the disc which you will obviously be able to feel. tighten a couple bolts on the tranny to hold it on. then thru the starter hole tighten each 10mm clutch bolt to the correct specs and rotate the crank so u can do it in the correct sequence also.
this is a last resort if for some odd reason u cant find an alignment tool
Old May 21, 2004 | 06:33 PM
DubyaAye's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu &raquo;</TD></TR><TR><TD CLASS="quote">
if you have drive shaft off the broken tranny that will work better than anything. </TD></TR></TABLE>with the shaft, tranny fit in like a glove.
Old May 21, 2004 | 07:17 PM
AL ASPIRATED's Avatar
kragen
Old May 21, 2004 | 10:46 PM
DubyaAye's Avatar
Default Re: (AL ASPIRATED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AL ASPIRATED &raquo;</TD></TR><TR><TD CLASS="quote">kragen</TD></TR></TABLE>called around most of the auto parts store and none of them had it, i even call the performance shop but with no luck. luckily i have a broken tranny that i can use the shaft.
Old May 21, 2004 | 10:53 PM
Default Re: (DubyaAye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye &raquo;</TD></TR><TR><TD CLASS="quote">called around most of the auto parts store and none of them had it, i even call the performance shop but with no luck. luckily i have a broken tranny that i can use the shaft.
hrmm did kragen really stop renting them out?
i noe they did before
tacchan
26
Mar 17, 2010 11:25 AM
badpootie
19
Jun 20, 2005 09:47 AM
RTW DC2R
Feb 11, 2005 04:37 PM
wkrpfm
Acura TL, RL & ZDX
Dec 3, 2004 09:35 AM
fastlude69
Jul 14, 2004 07:12 PM
