running 75 shot, blew motor, what happened?
Old May 18, 2004 | 06:51 AM
hatchback_al's Avatar
Default running 75 shot, blew motor, what happened?
ok so i was running a 75 shot on my d16y7 with upgraded plugs and wires, thats it. then the motor just shut off by itself in the middle of spraying. i restarted it and it wouldnt stay running unless i kept my foot on the gas and was running poorly when accelerating like on 3 cylinders. what do you think happened? the motor is now out of the car but im just curious to see what you guys think got damaged. anything internally?
Old May 18, 2004 | 06:53 AM
hoggy's Avatar
Did you even check the plugs before pulling the motor?
Old May 18, 2004 | 06:54 AM
blackmagicCRX's Avatar
Default Re: running 75 shot, blew motor, what happened? (hatchback_al)
Did you retard the timing? I melted the ring lands off two pistons on a 90 shot. It would barely stay running and it sputtered a lot. good luck man
Old May 18, 2004 | 06:59 AM
yellowturbo's Avatar
maybe one of your plug melt ??? if your timing was stock .... look at your plugs they could tell you all the story lol
Old May 18, 2004 | 08:35 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote">Did you even check the plugs before pulling the motor?</TD></TR></TABLE>
what all did u check????
Old May 18, 2004 | 08:46 AM
Turbo E's Avatar
ran lean and melted valves and pistons i bet.
Old May 18, 2004 | 08:51 AM
twkdCD595's Avatar
Default Re:
leaned out and/or detonated...
prolly took out the ringlands.
Old May 18, 2004 | 09:49 AM
slipslap's Avatar
Default Re: Re: (twkdCD595)
Were you running a wet or dry kit? Probably a dry and it leaned out burnt a plug. I ran several bottles of 75 wet shots in my 91 lude with no problems. When things go wrong with nitrous, it's usually lean or to big a shot. But the plugs should reveal all.
Old May 18, 2004 | 10:45 AM
Timmay's Avatar
Default Re: Re: (slipslap)
i bent you burned a valve, been there done that
Old May 18, 2004 | 01:12 PM
Default Re: Re: (Timmay)
well, the truth is it happened to my friend and i want his motor for a rebuild. i dont know exactly what happened or what he checked, thats all the info i have i was just looking for examples of what might have happened. what are the chances that the block is still good. i mean that i can put in new pistons and rods including bearings and rings and have it be strong again. what usually is fucked over from something like this happeneing
Old May 18, 2004 | 07:48 PM
Default Re: Re: (hatchback_al)
bumb
Old May 18, 2004 | 08:09 PM
oscarmayer's Avatar
fueling? what did you do to increase your fuel delivery? maybe you ran to lean and melted it due to that?
AJsB18
Jun 19, 2007 07:32 PM
The-LS
Feb 23, 2006 10:26 AM
punjones123
Feb 14, 2006 09:09 PM
krazykid
Apr 27, 2003 04:20 PM
BseriesHatch
Mar 25, 2003 08:34 AM
