Did I blow my motor?
Re: Did I blow my motor? (Black-LS)
yea or maybe just melted a plug. pull the plugs. if one is coated in oil, then you are fucked.
do a compression test too
Re: Did I blow my motor? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">plugs might be toast or u burned a valve, but i think just the plugs are toast, whats ur timing at?</TD></TR></TABLE>
Timing should be at about 16BTC
Modified by Black-LS at 11:06 AM 4/1/2006
Re: Did I blow my motor? (bdavis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdavis »</TD></TR><TR><TD CLASS="quote">yea or maybe just melted a plug. pull the plugs. if one is coated in oil, then you are fucked.
do a compression test too</TD></TR></TABLE>
when **** like this happens everyone change there plugs first just to see what happens 90% of the time people ask questions like this on here its plugs
Re: Did I blow my motor? (N20civicB18)
since you had some black smoke you might have got lucky and just toasted a plug.. when mine started to sound like a wrx i had broke ringlands on 2 pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS »</TD></TR><TR><TD CLASS="quote">Oh yes... I guess that time may have come. Did a 3rd gear pull with my FMU JRSC and towards the end it was just letting out a large plum of black smoke. Shouldn't that be rich? Anyways. Later when I got off the freeway my car sounds like a WRX tugboat and idle is very rough. The car is a bit hot for me to check. But what would cause the car to run rough and have a rough idle? As the RPMs get higher, the car seems okay. But as RPM gets lower its rougher and the car shakes more with the roughness. </TD></TR></TABLE>
get rid of the fmu
get rid of the fmu
Re: Did I blow my motor? (vtac sonn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtac sonn »</TD></TR><TR><TD CLASS="quote">get rid of the fmu </TD></TR></TABLE>
I just put it back! lol. I had the injector and standalone before but had to get smogged at test only so yada yada yada and was thinking about selling the car in this form so its legal... than this just happened.... so I can't check it out until this weekend since I'm out of town on work... driving the WRX sounding integra
okay, drove it again this morning and saame symtoms. (Again I'm out of town away from home and have no tools to work on the car other than a screwdriver). But I was wondering, if guesses to my problem could be narrowed down. The car feels like its missing, which goes along with the plug problem. But as the RPMs climb, the problem/miss is not as noticeable.
I've also driven cars with blown ringlands and it didn't miss or drive like this. Also my car has NO smoke from the tail pipe as of now when I drive it.
I'm going to search on the symtoms of a burned valve, don't really know what that means.
as of now I'm still driving a integra that sounds like its powered by a WRX Tugboat motor.
Re: Did I blow my motor? (rondigs)
well hes kinda of stuck so hes gonna have to drive it.
I bent a valve in a gsr once and it did the same thing.Lower RPM's it was real rough but then smoothed out in higher R's. It was still noticable in all RPM's though.
was seaching around and came across this thread https://honda-tech.com/zerothread?id=1524702 sounds pretty similiar to my symtoms but my car still starts and runs. hmmm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdavis »</TD></TR><TR><TD CLASS="quote">go buy a rachet and 5/8 socket and check your plugs. it will cost like $20 for everything!</TD></TR></TABLE>
took your advice. Cylinder #1 was fouled with fuel. I just put in a new plug and still it drives the same. Is it possible this is a ignition problem? Going to try to take the dist. cap off during my lunch break to see if anything is wrong in there. Also I do hear a audible ticking sound. I'm guessing a bent valve? But I didn't over rev the motor. This all started during a freeway pull probably in 3rd and when I saw a huge plume of BLACK smoke in my rearview mirror I let off... I was probably at about 7000 RPM then.
Re: Did I blow my motor? (DJ Gurgla GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Gurgla GSR »</TD></TR><TR><TD CLASS="quote">Did you change all the plugs? Or just cyl #1?
Next step is a compression and / or leakdown test. </TD></TR></TABLE>
well if you dont have a compression tester at home, i would pick one up as well from autozone or whatever. it will be like $30 - 40. and its just as easy as changing the plugs
good luck
good luck
