Better 1/4 mile times
holla guys,
i'm from australia and i drive a 95 Civic SIR, these are my mods:
OZ Racing % spoke 15x7
Toyo r881 Tramphio 195/55 ZR 15
B16A JDM specs
JDM specs 4-2-1 extractors
K&N fliter
2 1/4 piping
Jacobs External coil
Jacobs Ignition module
Unichip Ecu (piggyback)
Exdey heavy duty clutch
ligthen flywheel
toda B adj cam gears
my best time is 14.6
what extra mods i can do to get a flat 14s
any help will do...thanks
toNy
B16A JDM specs
K&N fliter
2 1/4 piping
ligthen flywheel
toNy
I guess the question is where do you want to skew the powerband? You could go with something like ITR cams but you'll be paying a small fortune for them from Honda Australia or alternatively get cams from one of the aftermarket manufacturers.
There are a million and one posts on these so your best option is to search through the archives for topics titled <insert manufacturer here> cams. eg - ITR cams, JUN cams, Toda cams, Skunk cams, etc.
https://honda-tech.com/zerosearch
I'd go with a cam that has an idle as close to stock as possible as a lumpier idle is just another reason to be given a canary these days.
How much octane is too much for a 1995 civic with a D16Z6, i want to run preminum gas with eather nos octane booster that adds 3 points to octane or racing nos octane booster that adds 7 points of octane, with out blowing my motor for drag racing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mR_cHiEf »</TD></TR><TR><TD CLASS="quote">holla guys,
B16A JDM specs
K&N fliter
2 1/4 piping
ligthen flywheel
toNy</TD></TR></TABLE>
14.6?
What was your trap speed? 60ft? Weight of car with driver?
That's about right if your 60ft was around 2.3...
Yea like those guys said the next step would be the camshafts...
B16A JDM specs
K&N fliter
2 1/4 piping
ligthen flywheel
14.6?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mR_cHiEf »</TD></TR><TR><TD CLASS="quote">holla dax-es...are there any proper honda clubs in Melbourne???
I'm not sure. I've only had experience with the Honda Sports Car Club when it first started. They had a track day once a year, a few drives around VIC, and motor show tickets from Honda. Apart from that, the only other one is the Honda Club which I don't know about but I suspect it's much the same.
At the other end there is something like MCCR http://www.melbccr.com/.
