HELP with turbo LS/Vtec?
Old Nov 7, 2001 | 06:19 AM
cornbread's Avatar
Default HELP with turbo LS/Vtec?
I posted this in the FI and integra board and no one responded to me. I really need this info ASAP before i install the motor if any one can help.
Well i just bought a LS/Vtec for little to nothing. The bottom end is off a 95 LS with about 90miles on it. The head is off a 99si. I'm planing on boosting it and i don’t think the LS bottom end will last too long stock with that many miles on it. I would like some ideas of what i should get for it, what kind of pistons and all the goodies. I'm planing on boosting around 12psi at the track and 7psi for daily driving. Can some one help me out give me web sites where i can get more info if you can’t help.
Thanks Shane
Old Nov 7, 2001 | 07:05 AM
rainforest's Avatar
Default Re: HELP with turbo LS/Vtec? (smokeeeLSR)
low budget arp rod bolts and head studs. shot peined rods. new bearings and seals. vtec oil and water pump. That will cost you like less 700 dollars if you are thrifty.
high end budget same thing just endyn rods and pistons.
Old Nov 7, 2001 | 07:14 AM
cornbread's Avatar
Default Re: HELP with turbo LS/Vtec? (rainforest)
Can you give me any web sites where i can check some of these parts out?
Old Nov 8, 2001 | 08:40 AM
GM2000ITR's Avatar
New User
I agree with rainforest, "low budget arp rod bolts and head studs. shot peined rods. new bearings and seals. vtec oil and water pump" You should, at the very least, purchase these items...It will save you tremendous headache(not to mention possibly thousands to repair)! Good Luck!
g0tgot
Aug 30, 2008 10:59 AM
SUPERSONICGSR99
May 26, 2007 08:05 PM
mountaindewguy
19
Jan 28, 2006 10:32 AM
Speed_Dreams
Jul 27, 2003 01:48 PM
cornbread
Nov 7, 2001 09:15 AM
