piston compresion ratio
Old May 17, 2004 | 07:40 PM
vtec_lude96's Avatar
Default piston compresion ratio
im in the process of rebuilding my h22 for a turbo, but don't know what compresion ratio i should get. I've researched and found that 8:5:1 is good for dsm's but couldnt find anything for hondas. If anyone knows what would be best please let me know. thnks
Old May 17, 2004 | 08:20 PM
satan_srv's Avatar
Default Re: piston compresion ratio (vtec_lude96)
depends on what turbo you are running. As long as you have good fuel management I would go with 9.5:1 you'll make good power.
Are you sleeving the block? Hope so..
Old May 19, 2004 | 05:47 PM
Default Re: piston compresion ratio (satan_srv)
Yea iam having a maching shop sleeve the block, iam also getting new pistons, rods, head gasket, and arp head studs. I am planning on running either the t3/t4 or this ball bearing turbo from slowboyracing called the disco potatoe they say can run easily 20 psi. so is there anything else i should do to my internals so i can run big psi?
ej_jake
Aug 28, 2017 08:46 PM
Hulk22
Oct 19, 2005 06:33 PM
LilCivic04
May 31, 2005 09:12 AM
LilCivic04
Feb 1, 2005 06:04 PM
96EkTurboHatch
Aug 26, 2002 10:00 PM
