b16a block w/ b16a2 head piston ?
Old May 17, 2004 | 06:31 PM
92hatchb18's Avatar
Default b16a block w/ b16a2 head piston ?
should I use the stock pistons or the gsr pistons and rods will rods work ann I already searched came up w/ results but would like your info thanks must replace piston rings is the reason for the question
Old May 17, 2004 | 06:34 PM
simplestyles's Avatar
Default Re: b16a block w/ b16a2 head piston ? (92hatchb18)
the rods are the same as b16 the only diff is the crank
Old May 17, 2004 | 08:07 PM
mmuller's Avatar
Mad Scientist
Default Re: b16a block w/ b16a2 head piston ? (simplestyles)
hehe, gsr pistons on your b16 will yield a lot lower compression than your stock pistons...
gsr rods are not the same as b16.....
jdmbwoy
Feb 24, 2007 07:20 PM
killerB16A
Jul 28, 2006 09:30 AM
turbotime
Mar 20, 2006 08:20 PM
Lou_EM1
11
Feb 22, 2006 06:32 PM
vtecn8ive
Oct 4, 2005 06:40 PM
