Fan turning on too late or thermostat not working?? Need help please
Old Nov 7, 2001 | 05:49 AM
REDBARON's Avatar
Default Fan turning on too late or thermostat not working?? Need help please
Ok guys here's my dilema. My car is running pretty hot. Above halfway on the gauge, and it's starts getting hot when I sit in traffic, but then goes back down a little when I'm driving. I jumped the fan, and it turns on right away. Now also I've noticed that when the temp gets about 3/4 of the way up, then the fan kicks in..?? Isn't that too late? Or maybe the thermostat is not openning up like it should and causing it to overheat?? I'm not sure what the problem is, but when it gets pretty hot the coolant overflows and gets spilled out. Help me out guys.
Also here's my setup. I have a 95 Sohc Vtec in my 90 civic hb.
Old Nov 7, 2001 | 07:08 AM
rainforest's Avatar
Default Re: Fan turning on too late or thermostat not working?? Need help please (VTECHatch)
check for your water pump and replace your thermostat.
Old Nov 7, 2001 | 10:36 AM
976's Avatar
976
New User
Default Re: Fan turning on too late or thermostat not working?? Need help please (rainforest)
Thermo switch seems to be working.
Also, a mixture of 8:1 ratio of water and coolent will be much hotter. Try to even it out perfectly. Could be about time to drain fluid. Please remember to dump coolent in sink rather than sewage drain. This world has been polluted enough.
Old Nov 7, 2001 | 11:33 AM
REDBARON's Avatar
Default Re: Fan turning on too late or thermostat not working?? Need help please (B21A)
Ok. I'll drain the coolant and put some new one in there.
tien2
Mar 12, 2009 02:55 PM
danteisme
Honda Motorcycles
Sep 18, 2006 06:00 PM
tianporn
Jul 29, 2005 11:44 PM
Evs-One
Jul 11, 2002 12:04 AM
REDBARON
13
Nov 28, 2001 11:38 AM
