Type R transmission oil?
Old Nov 7, 2001 | 04:29 AM
kkim's Avatar
Default Type R transmission oil?
I would like to change to a synthetic transmission fluid and was wondering what you guys would recommend. I have been using redline MTL in all of my cars and like the difference it seems to make in shifting smoothness. With the type R having a limited slip diff, can I still use MTL or does the limited diff take a different type of fluid? I would like to hear of what you would recommend and why... thanks
Old Nov 7, 2001 | 04:38 AM
eg6ajk's Avatar
Default Re: Type R transmission oil? (kkim)
my personal prefrence is just honda MTF....makes gears smooth and doesn't void warranty...also i heard that sythentic, oils are way too thin for the tranny, and might cause problems...others use MTF and add some GM/Ford synchro/LSD additive...
Old Nov 7, 2001 | 06:52 AM
dplatt's Avatar
Default Re: Type R transmission oil? (eg6ajk)
Honda uses the same MTF for all of it's manual transmissions. This includes the ITR and NSX.
vlc92189
41
Aug 16, 2013 11:19 AM
TOO MUCH TORQUE
Jul 8, 2008 01:13 PM
Slomo_civic
Honda Motorcycles
Mar 17, 2008 12:51 PM
Gump
Feb 28, 2002 04:44 AM
