my car keeps on over heating so
what could it be,
iam geting kinda pissed off because i have to turn up the heater to get it to cool down. the tempeture go's up to max and then when i turn on the heat it go down what the ****. car going to **** help
head gasket...thermostat...radiator...search button...search button...search button.
many threads about this problem already, search button will lead you to the answer.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reason »</TD></TR><TR><TD CLASS="quote">i would say your thermostat is not opening.</TD></TR></TABLE>
don't say that. you haven't seen his car, you haven't given it an inspection. I strongly doubt he has. when the car is warm, press the two hoses and make sure you can feel the coolant flowing through. with your problem, chances are, you won't feel it. check your thermostat, radiator cap, fluid quality and level, water pump and belt, radiator blow, head gasket....give it a thorough inspection.
Check to see if your fans come on by themselves. While waiting for you car to warm up feel the top hose and bottom hoses. both hoses should be nice and hot after a while. If the bottom one doesn't heat up then thermostat..
heres a thread from earlier today check it out
https://honda-tech.com/zerothread?id=867366
Why would you make 2 threads same question?
Are you losing coolent?
if so where is it going? If no visable leaks in engine bay (will show green dried residual) Then see if you have coolent in your with a oil change.
