VAFC
Old May 17, 2004 | 02:32 PM
Groove_D's Avatar
Default VAFC
ok, i got this today, but since its used and has no instructions, i cant figure out where was it plugged.
can someone tell me if he know where the plug was plugged in?
here is the pic
Old May 17, 2004 | 02:38 PM
jh4db536's Avatar
Default Re: VAFC (Groove_D)
um ur supposed to splice that to ur ecu harness, either that or buy a premade jumper harness for like 150....
gl and dont install it wrong or all electronic hell is gonna break loose.
Old May 17, 2004 | 02:39 PM
Marauder's Avatar
The VAFC comes with another harness that plugs into that end, and the other end you splice into the factory harness. Guess you didn't get that other little harness end.
Old May 17, 2004 | 02:47 PM
Audi A4's Avatar
Default Re: VAFC (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">The VAFC comes with another harness that plugs into that end, and the other end you splice into the factory harness. Guess you didn't get that other little harness end.</TD></TR></TABLE>
excato... is that all u got...
Old May 17, 2004 | 02:54 PM
Groove_D's Avatar
so what should i do if i didnt get that other harness end?
yea, thats all the guy sent me.
Old May 17, 2004 | 03:10 PM
B00ST2nR's Avatar
you gotta look around for one. I believe there was some guy here in the integra forum who had the other harness for sale for $20.
The guy is sucka306
And you can see this thread:
https://honda-tech.com/zerothread?id=865073
Old May 17, 2004 | 03:14 PM
mini-v-si's Avatar
do what I did if you don't want to buy that harness, the other harness is use as a extension, I didn't have that so I use some good wires, I used speaker wires equivalent to the one sticking out from the unit. make sure you follow the instruction. Go to apexi and download instruction from there and please take all 43 pages into consideration.
Old May 17, 2004 | 03:30 PM
Groove_D's Avatar
Default Re: VAFC (94tegGSR)
i just really dont feel like rewiring all those 11 wires.
and did you get them in the same color?
thanks to all the replies guys.
Old May 17, 2004 | 03:38 PM
mini-v-si's Avatar
pretty much simple, thats what I said in the first place almost pay the shop to do but just sit down and read the instruction, you'll get it done in less then an hour. just make sure you follow the wires if they are not color coated, I prefer equivalent wires because you don't want to have a big extension cord coming from the ecu.
wizeguy1
Apr 14, 2007 02:21 PM
JDMflavor_EJ
May 9, 2004 05:06 PM
KCHybrid
Jun 15, 2003 04:46 PM
ModlesSI
Feb 11, 2003 05:18 PM
