Highest Compression for 93 Octane
Old Nov 6, 2001 | 10:08 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Highest Compression for 93 Octane
Whats the Highest compression i can run in my B18c1 on pump 92/93 octane?
Old Nov 6, 2001 | 10:12 PM
Stunna BEN's Avatar
Default Re: Highest Compression for 93 Octane (Big Carbon)
Ive heard 11.4:1 but then again i see people running higher and i hear about these rollerwaves by Endyn???
Type Goch's Avatar
New User
people run that CR on pump 91 octane. You can probably run up to 12's with a problem. If youre unsure about it, you can always get yourself a J&S safeguard.
[Modified by Type Goch, 11:13 PM 11/6/2001]
Old Nov 6, 2001 | 10:17 PM
Stunna BEN's Avatar
Default Re: Highest Compression for 93 Octane (Type Goch)
I liked the idea of the CTR pistons but wasnt sure if id be able to on pump gas
Old Nov 7, 2001 | 02:57 AM
rainforest's Avatar
i have 12.1 endyns...93 octane
Old Nov 7, 2001 | 04:12 AM
Red Civic T's Avatar
New User
Default Re: Highest Compression for 93 Octane (rainforest)
CTR pistons with no probs. (and a milled head)...
Old Nov 7, 2001 | 08:25 AM
Stunna BEN's Avatar
Default Re: Highest Compression for 93 Octane (Red Civic T)
Will i have to mill the head of my b18c1 to run those ctr pistons?
Old Nov 7, 2001 | 08:30 AM
3rdShift.org's Avatar
New User
Hopefully 93 octane
Old Nov 7, 2001 | 09:01 AM
MysteryWagon's Avatar
Default Re: Highest Compression for 93 Octane (3rdShift.org)
right at 11.6 is the safest.......I think 12.1 is pushing it.
Old Nov 7, 2001 | 09:11 AM
Stunna BEN's Avatar
Default Re: Highest Compression for 93 Octane (ShaggenWaggon)
What will the ctr be in the b18c1 block and in the b18c5 block?
Old Nov 7, 2001 | 09:14 AM
Max GSR's Avatar
I have 12:1 Endyn running 93 with no problem. I wouldn't go any higher than that, and you better have some headwork to help out with air flow to burn it all. You also won't need to advance your timing to get you power with this setup!
Old Nov 8, 2001 | 08:36 AM
GM2000ITR's Avatar
New User
I'm running 12.5:1 in an LS/VTEC (full P&P, ITR valves, Kawasaki springs, Ti. ret.,Skunk2 cams, CTR pistons, etc.)on 93 Octane at about 14 degrees (shooting for a J&S soon to set it at 18 deg. and let the bitch run!) - no probs. even in hot humid FL! Good Luck!
[Modified by GM2000ITR, 5:36 PM 11/8/2001]
kantfadedisazn
21
Sep 17, 2006 11:10 PM
DCnotTHEshoes
Mar 20, 2006 03:03 PM
JDM_Spec
Jul 17, 2005 10:11 PM
redteg
Apr 23, 2003 10:56 PM
DarkSubRosa
Feb 28, 2002 03:57 PM
