LS vs GS-R?
Old May 16, 2004 | 07:50 PM
bigblizz49's Avatar
Default LS vs GS-R?
I did a search and nothing turned up. I have a 95 Ls SE, I want to swap a b18c1 in, but ive heard that Ls VTEC is faster with supercharger or turbo? Whats your thoughts. Im open for any replies.
Old May 16, 2004 | 07:57 PM
MolecularIntegra's Avatar
Default Re: LS vs GS-R? (bigblizz49)
And LS VTEC can be faster than a b18c, yes. But it's all in how you build it. You have to do a lot of research and build it right ($$$) to make it work. Obviously a super/turbo charged anything will be faster than an NA version. This question is really to general to answer...
Old May 16, 2004 | 07:58 PM
5spdIntegra's Avatar
Well you suck at searching if nothing came up for ls/vtec.
Here is my reply before this gets locked.
Turbo your motor. That will be the cheapest and easiest way to make power for you.
Old May 16, 2004 | 08:00 PM
m R g S r's Avatar
Default Re: LS vs GS-R? (5spdIntegra)
Yea, search in the ARCHIVED posts. That's where all the information lies. Damn newbies!
Old May 16, 2004 | 08:21 PM
bigblizz49's Avatar
Default Re: LS vs GS-R? (MolecularIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MolecularIntegra &raquo;</TD></TR><TR><TD CLASS="quote">And LS VTEC can be faster than a b18c, yes. But it's all in how you build it. You have to do a lot of research and build it right ($$$) to make it work. Obviously a super/turbo charged anything will be faster than an NA version. This question is really to general to answer...</TD></TR></TABLE>
thanks alot for posting, im going to search some more. If any body else has info please post.
Old May 16, 2004 | 08:26 PM
tekstyle's Avatar
LS vtec with turbo is probably the fastest setup u will get. the other option is getting a K20 type s motor and then turboing that, which is basically something totally different from what u had in mind i assume.
Old May 17, 2004 | 01:32 AM
IntEGNYC's Avatar
Default Re: LS vs GS-R? (tekstyle)
if youre asking... im guessing you shouldnt go down this route.
Old May 17, 2004 | 07:59 AM
DGibb's Avatar
Just do LS Turbo build-up (like me), VTEC is over-rated.
The best setup for a turbo is low compression and no extra variables (aka VTEC, VVTI, ect ect, anything that will basically add a double boost effect).
Just my 2 cents anyhow...
Old May 17, 2004 | 08:06 AM
Goinfasterthanu's Avatar
dgibb is VERY right!!! Ls turbo setup is the way to go..and is a LOT easier to tune!!
Old May 17, 2004 | 08:44 AM
ru2slo's Avatar
Default Re: (DGibb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DGibb &raquo;</TD></TR><TR><TD CLASS="quote">Just do LS Turbo build-up (like me), VTEC is over-rated.
Just my 2 cents anyhow...</TD></TR></TABLE>
yup. ls-t owns me.
Old May 17, 2004 | 09:59 AM
Kendall's Avatar
If it were me, I'd sell the engine and swap in an H22. But of the previously listed options, an LS turbo would probably be the simplest and most cost effecient.
Old May 17, 2004 | 10:08 AM
VTECorona's Avatar
Default Re: (Kendall)
I would do a turbo h22 setup, H22's can be had for like 2 grand these days. That's probably not the answer you are looking for though. GSR swaps run what, 3500? That's about the cost of a turbo kit and it will get you 3+ times power increase over going from ls-&gt;gsr. PLUS a turbo is much funner to play with than VTEC, trust me.
Old May 17, 2004 | 10:54 AM
MikeTV
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">LS vtec with turbo is probably the fastest setup u will get. the other option is getting a K20 type s motor and then turboing that, which is basically something totally different from what u had in mind i assume.</TD></TR></TABLE>
The guys around here have had nothing but trouble trying to turbo K20s.
Old May 17, 2004 | 11:58 AM
SIK IN DA HED's Avatar
New User
Default Re: (DGibb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DGibb &raquo;</TD></TR><TR><TD CLASS="quote">Just do LS Turbo build-up (like me), VTEC is over-rated.</TD></TR></TABLE>
Old May 17, 2004 | 12:30 PM
bigblizz49's Avatar
Default Re: (DGibb)
ok but my motor has 120k on it is this ok to for turbo or should I swap a lower mil eng in there?
Old May 17, 2004 | 12:33 PM
bigblizz49's Avatar
Default Re: (bigblizz49)
And on Bump for all the good info. Im loving honda-tech
Old May 17, 2004 | 12:42 PM
Audi A4's Avatar
why are u bumping a thread after 3 mins.. they dont allow that here just a heads up
oh yaeh go ls turbo
Old May 17, 2004 | 01:12 PM
bigblizz49's Avatar
Default Re: (DRAG lll INTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAG lll INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">why are u bumping a thread after 3 mins.. they dont allow that here just a heads up
oh yaeh go ls turbo</TD></TR></TABLE>
ok. thanks for the info
Old May 17, 2004 | 01:40 PM
Professor X's Avatar
It really depends on what you want. I have owned 2 LS's, a 2nd gen Gs-R with a b17 and a 2nd gen turbo with a B18c . All of them had different personalities. All were fast and I enjoyed them all. Whatever you do, don't let someone else tell you what you need. I did that with turbo. I didn't really want it, but I let h-t and a load of others convince me thats what I wanted. Now I am trying to sell it. Not because it isn't fast, reliable, or anything, but because I would prefer a simplar setup for the time being. Be sure you research the maintenance requirements for whatever setup you choose. Also be sure that the people giving you advice are giving you advice based on personal experience. Other than that, be sure to have fun! :D
Old May 17, 2004 | 01:53 PM
gundamgsr's Avatar
Default Re: LS vs GS-R? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Yea, search in the ARCHIVED posts. That's where all the information lies. Damn newbies!</TD></TR></TABLE>
you are sooo cool!
Old May 17, 2004 | 01:55 PM
BLacK FirE's Avatar
I have an ls that I plan on turboing (next year tho probably). I'm choosing this way because I used to own a turbo car (volvo) and I've driven my friends wrx and turbo is loads of fun to drive. As for the milage of your motor, if all of the owners have taken good care of the car it shouldn't be too much of a problem but to play it safe you can upgrade the internals, but of course that's more money that you will need to save/spend.
Old May 17, 2004 | 01:56 PM
hotintegranights's Avatar
Default Re: (Professor X)
i would stay with the ls and rebuild the bottom end and drop the turbo in there, remember turbo ls are great motors to turbo,many people in here have had many success with them, and make as much in some case more torque than gsr turbo, and def more than b16 turbo.
Old May 17, 2004 | 03:48 PM
slo2kgsr's Avatar
Default Re: (hotintegranights)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblizz49 &raquo;</TD></TR><TR><TD CLASS="quote">
ok but my motor has 120k on it is this ok to for turbo or should I swap a lower mil eng in there?</TD></TR></TABLE>
If you did the ls/vtec you would have to rebuild anyways. Basic rebuild would just be piston rings, rod bearing, and maybe crank bearings if you are worried about them. Keep your motor and turbo or buy another and build the intenals and turbo then swap the rebuilt ls for yours and sell yours on ebay or keep as a spare motor.
Old May 17, 2004 | 05:44 PM
bigblizz49's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Professor X &raquo;</TD></TR><TR><TD CLASS="quote">It really depends on what you want. I have owned 2 LS's, a 2nd gen Gs-R with a b17 and a 2nd gen turbo with a B18c . All of them had different personalities. All were fast and I enjoyed them all. Whatever you do, don't let someone else tell you what you need. I did that with turbo. I didn't really want it, but I let h-t and a load of others convince me thats what I wanted. Now I am trying to sell it. Not because it isn't fast, reliable, or anything, but because I would prefer a simplar setup for the time being. Be sure you research the maintenance requirements for whatever setup you choose. Also be sure that the people giving you advice are giving you advice based on personal experience. Other than that, be sure to have fun! :D</TD></TR></TABLE>
you guys dont now how much I apreceate this information.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegraLS97 &raquo;</TD></TR><TR><TD CLASS="quote">
If you did the ls/vtec you would have to rebuild anyways. Basic rebuild would just be piston rings, rod bearing, and maybe crank bearings if you are worried about them. Keep your motor and turbo or buy another and build the intenals and turbo then swap the rebuilt ls for yours and sell yours on ebay or keep as a spare motor.</TD></TR></TABLE>
I think this will be the way to go and im going to research the maitence on the setup that I chose. Thanks for helping me. keep posting your info im saving most of this stuf for the future.
patrickp1999
Apr 21, 2012 03:20 AM
kbear
Aug 16, 2006 05:08 PM
teguy
Dec 1, 2005 05:53 AM
blackknightg2
Feb 2, 2005 08:54 PM
Fuzion
Nov 17, 2003 09:00 AM
