Anyone ever use these spark plugs in their setup??
Old May 16, 2004 | 02:27 PM
ringgold's Avatar
Default Anyone ever use these spark plugs in their setup??
Alright back in the day I had a Civic with a D16Y8 in it and I had a dry shot of nitrous on it. Darrell *** if anyone knows who he is told me to run Champion C59 Race Plugs in it because of the nitrous and these plugs were colder and worked really well with nitrous.
I still have them and just installed them into my SR20DET which was wanting to lean out last night with the new plugs that I installed in it some NGK BKR6ES-11. I know that the heat range on these plugs is a little on the hot side for turbo but I have ran them before without any real problems. Last night on the other hand my car wanted to sputter when I would boost it up so I decide to check my plugs. Low and behold the tips are white!!!!!!! I took them out and threw in some old Denso plugs that I had just took out and it ran alot better.
I just wanted to know if anyone ever experimented with these plugs and if they liked them or not. Any pros or cons
Old May 16, 2004 | 03:03 PM
numba1's Avatar
Default Re: Anyone ever use these spark plugs in their setup?? (ringgold)
nope never tried them before. always used ngk bkr7 or bkr8 in my FI rides,boosting at least a bar.
Old May 16, 2004 | 03:24 PM
ringgold's Avatar
Default Re: Anyone ever use these spark plugs in their setup?? (numba1)
Cool I just went on a little test romp with my car. It ran about like it always has with the Champion C59's in it. Ill give them a few days and see how it turns out.
It seems like my plugs are a lighter shade then they have been in the past. Is it possible that I have got some bad gas in the tank? Making it run leaner
Old May 16, 2004 | 04:48 PM
MAX_CFM's Avatar
I use them
NASCAR plugs
Old May 16, 2004 | 05:09 PM
ringgold's Avatar
Default Re: Anyone ever use these spark plugs in their setup?? (MAX_CFM)
So they should be pretty good for my forced induction setup right??
Old May 16, 2004 | 05:41 PM
rioninja's Avatar
I've always had good luck with champion plugs..
sting94112
Apr 18, 2004 04:26 AM
tkHBseries
Mar 30, 2004 10:48 AM
crxb18c5
Aug 5, 2002 07:53 AM
