What work do you trust to local machine shops vs sending it to Honda "pros"?
Old May 16, 2004 | 10:56 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default What work do you trust to local machine shops vs sending it to Honda "pros"?
Well I'm about ready to start my first engine build. Like anyone I'm nervous as crap about getting it all together again correctly, but I plan on taking my time and in the end it should be fun/good experience.
However I will be needing some basic machine work done and I'll a little nervous about sending it out to local Alabama machine shops.
I will be needing the following:
1. Bore and hone.
2. Crank balancing and micro polish (micro polish probably not nessecary but I'd like to have it done anyway)
3. Rods reworked after installation of ARP rod bolts (pretty sure I have to do this).
4. Pistons put on rods.
5. Head checked over, new valve seals, and installation of my new valve springs and retainers.
I'm most concerned with someone touching my head. Mainly because the last time I had a local machine shop touch it I had major problems. The head sealed good but I was running MAJORLY lean with the same tune and no other changes. I'm not sure if they shaved too much or what but it just put a bad taste in my mouth.
Old May 16, 2004 | 11:12 AM
Dan GSR's Avatar
Default Re: What work do you trust to local machine shops vs sending it to Honda "pros"? (ActiveAero)
only hear good stuff about Brad
http://www.hondaraceengines.com/
Old May 16, 2004 | 04:06 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: What work do you trust to local machine shops vs sending it to Honda "pros"? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">only hear good stuff about Brad
http://www.hondaraceengines.com/</TD></TR></TABLE>
Yeah he will probably be recieving my head.
Old May 16, 2004 | 04:24 PM
NiceDc2r's Avatar
head ggod stuff about them
Old May 16, 2004 | 04:45 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah he will probably be recieving my head.</TD></TR></TABLE>
he does blocks well too, not everyone does bore/hone with deckplate
Brad does
silkyj87
Northwest
Nov 12, 2011 01:46 AM
Zor_Primo
South
Feb 23, 2011 08:55 PM
d-series-buildup
Nov 17, 2007 11:15 AM
jvtec95
Sep 18, 2006 10:09 PM
turbodsmpower
Dec 13, 2002 06:05 AM
