JDM OEM intake:::: where does it go?
Old May 16, 2004 | 10:54 AM
bboyprelude's Avatar
Default JDM OEM intake:::: where does it go?
http://cgi.ebay.com/ebaymotors...38634
i was wondering where the air would enter from, if that's a true jdm 4th gen stock intake, why would they put it behind the driver's side wheel well instead of at the front near a nostril?
i guess i now know why honda put a circle there on usdm preludes and didn't drill it out. once again, japan gives us the finger
Old May 16, 2004 | 12:35 PM
VTECR021's Avatar
Default Re: JDM OEM intake:::: where does it go? (bboyprelude)
it goes on the passenger side, and the bottom thing on the filter box is the intake resonator, to keep noise level down, that will need to go under the car, take the wheel well liner off and then align the top into the hole and bolt it on, then put the air box on top of the hole and plug the tube into the throttle body.
Old May 16, 2004 | 12:46 PM
Sam1am26's Avatar
There is no difference between the 92-96 jdm and usdm intakes though...
Old May 16, 2004 | 01:40 PM
Default Re: JDM OEM intake:::: where does it go? (Sam1am26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">There is no difference between the 92-96 jdm and usdm intakes though...</TD></TR></TABLE>
did you not check out that link. 902-96 usdms didn't come with that extended air intake. usdm stops at the filter. that pic shows it continuing...
if i'm wrong school me....
Old May 16, 2004 | 01:45 PM
optikal_blitz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboyprelude &raquo;</TD></TR><TR><TD CLASS="quote">
if i'm wrong school me....</TD></TR></TABLE>
well, if you haveve ever removed your resonator, you'd know that getting that "extension" out is a complete bitch. at least for me it was. the usdm and jdm intakes are the same, and the resonator comes before the filter, so it wouldnt just stop at the filter box...
Old May 16, 2004 | 01:54 PM
Mykizism's Avatar
that looks pretty much like a stock US 5G prelude air box assembly
Old May 16, 2004 | 02:26 PM
DW's Avatar
DW
Default Re: JDM OEM intake:::: where does it go? (Mykizism)
thats a stock 4th gen intake. the air enters from that random tube that comes off the resonator. (that big black box below the air filter housing)
all 92-96 usdm and jdm intakes are the same.
David
Old May 16, 2004 | 02:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">that looks pretty much like a stock US 5G prelude air box assembly</TD></TR></TABLE>
I know not to trust the average ebay seller, but the guy was passing it off as a 4th gen stock intake...
Old May 16, 2004 | 02:37 PM
DW's Avatar
DW
but the guy was passing it off as a 4th gen stock intake...</TD></TR></TABLE>
because it is, mine looks exactly like that in my 95SI
David
Old May 16, 2004 | 04:45 PM
Default Re: JDM OEM intake:::: where does it go? (DW)
damn i just realized i was srong all along. i wasn't thinking about the resinator coming out. the times i have taken out my intake i only took out the top half of it.
by bad
Old May 16, 2004 | 05:51 PM
stubk20's Avatar
you should go for the jdm type s airbox it flows better than the us airbox and it still looks stock.
Old May 17, 2004 | 07:35 AM
DW's Avatar
DW
Default Re: JDM OEM intake:::: where does it go? (stubh22a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stubh22a4 &raquo;</TD></TR><TR><TD CLASS="quote">you should go for the jdm type s airbox it flows better than the us airbox and it still looks stock. </TD></TR></TABLE>
or just take off the resonator and call it a day without spending any money
David
Old May 17, 2004 | 08:02 AM
Mario.'s Avatar
Or you can hide a cold air intake in the stock rubber piping and call it a day.
Old May 17, 2004 | 08:13 AM
Nikoli's Avatar
Default Re: JDM OEM intake:::: where does it go? (mariowc)
i have a 92-96 usdm airbox fs if anybody wants it?
Old May 17, 2004 | 04:19 PM
DW's Avatar
DW
Default Re: JDM OEM intake:::: where does it go? (95deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mariowc &raquo;</TD></TR><TR><TD CLASS="quote">Or you can hide a cold air intake in the stock rubber piping and call it a day. </TD></TR></TABLE>
haha, never thought about that before
David
Old May 17, 2004 | 04:47 PM
5hif7's Avatar
U think that the plastic would shield the CAI from heat? or would it just be better to wrap the pipe?
Old May 18, 2004 | 07:26 PM
Mario.'s Avatar
Default Re: JDM OEM intake:::: where does it go? (5hif7)
It was an idea I've seen on another Prelude... pretty cool IMO.
sRa-ah muy keol 7126
10
Dec 15, 2007 12:03 PM
Ill
Jul 12, 2004 09:38 PM
5-SpeedFreak
May 31, 2003 05:01 AM
h46it
Feb 17, 2003 08:12 PM
gokooljapan
Apr 30, 2002 02:44 PM
