Bottoming out...Question.
Old May 16, 2004 | 08:13 AM
GeeqH22's Avatar
Default Bottoming out...Question.
It wasn't too bad but it was loud.
My new 5th Gen prelude has eibach springs on it and I was at a gas station at night and there was a bump I did not see before the pump.
I hit the center support that goes from the front to the back below the header pretty hard. (It has that hook on the front) I was going only like 10mph.
Would that damage anything? Or am I just trippin?
Old May 16, 2004 | 08:56 AM
blackdelslo's Avatar
Default Re: Bottoming out...Question. (GeeqH22)
jack that sucker up and have a look see. We werent there, couldnt tell ya.
Old May 16, 2004 | 10:32 AM
satan_srv's Avatar
Default Re: Bottoming out...Question. (delLudeVTEC)
Most people with preludes have laid a severe beating on the center towhook...I wouldn't worry about it, at least it wasn't your header.
Unless you were driving into the gas station lot at 100 miles an hour I doubt you did anything except scrape it.
Old May 16, 2004 | 02:10 PM
wannabe's Avatar
Did you upgrade your shocks when you replaced the springs? My OEM shocks only lasted a couple of months with the coilover springs. Once I replaced the OEM shocks with higher rate dampners (Koni yellows), the car quit bottoming out. Every time the car gets jacked up on a lift, I cringe at the damage on the bottom of the chassis. Houston's streets are horrible. Lots of dips, potholes, speed bumps. The higher rate springs require higher rate shock absorbers. Otherwise, it's just a matter of time before your stock shocks are shot.
Old May 16, 2004 | 06:40 PM
Boost Addict's Avatar
Default Re: Bottoming out...Question. (wannabe)
You prob didn't hurt anything, I have bottomed up pleanty of times. Just jack up the car and check, make sure you don't have an exhaust leak or anything else....
Old May 16, 2004 | 07:20 PM
MugenPoweredLude's Avatar
Default Re: Bottoming out...Question. (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">Most people with preludes have laid a severe beating on the center towhook...</TD></TR></TABLE>
this is true
especially for my lude and these damn PA roads
Ive hit the tow hook REAL hard on occasion...nothing wrong here
yea its scary and you feel like you almost ripped the engine out of its mounts but yea that tow hook....poor lil guy
Old May 16, 2004 | 08:51 PM
Mario.'s Avatar
Default Re: Bottoming out...Question. (MugenPoweredLude)
If you get some nice shocks, this problem would be much less of a concern.
Old May 17, 2004 | 04:21 PM
GeeqH22's Avatar
Well I bought the car from Cush Acura.
It has:
Eibach Springs
Monroe Sensa trec shocks
And 17" Konig Imagines
I was just wondering. But I think Preludes have much more support and stronger sub-frames as my prior civics
But yes I will be getting Koni Yellows in a few months once I save up. I love the height it's at and don't want to change it.
Old May 17, 2004 | 04:26 PM
SKDRCR's Avatar
you also might want to take a look at your oil pan and
make sure you didn't dent that either
WONTONnPHO
Aug 17, 2009 03:46 AM
khronicboy420
Jan 30, 2009 04:36 AM
Tzer
Mar 10, 2006 10:00 PM
South Bay Surfer
Jul 18, 2005 10:12 AM
5200BB6
Jan 6, 2005 11:58 PM
