JDM ITR suspension and brakes install on USDM Integra GSR
I finally managed to get my JDM ITR stuff installed on my GSR.
It's been a royal pain because it was hard finding the correct information.
The JDM Integra type R has 36 mm axles vs. 32 mm for all USDM Integra and
Civic axles.
Anyway, here's what works:
91-93 accord, 97-2001 prelude axles--leave the inner CV joint in the intermediate shaft and graft the prelude or accord axle on to that.
18 inch heavy duty zip ties work (there's a tool at Home Depot to tighten it real good) instead of the metal band.
I tightened mine on the car car and it was easier than trying to tighten the metal ones.
The right side accord or prelude axles fit as is.
I also had to get new axle nuts from Honda.
I heard that the next best upgrade while keeping it Honda engineered would be NSX rotors and calipers if you can find those cheap
While the suspension was lying on the ground, I chose to get Mugen hard rubber bushings. They're not cheap but the polyurethane ones I have aren't all that great.
I've heard that there's a reason why Honda didn't totally enclose the rear trailing arm bushing. The thing needs to move laterally in a controlled manner. My poly bushings back there were just sliding around. Keep it Honda engineered.
pics (The rotors are rusted but it's on there):
Civic axles.
.While the suspension was lying on the ground, I chose to get Mugen hard rubber bushings. They're not cheap but the polyurethane ones I have aren't all that great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trellix78 »</TD></TR><TR><TD CLASS="quote">
Civic axles.</TD></TR></TABLE>
Interesting, never knew that. But why not just get USDM Type R stuff? Bigger or was for Bling Blang JDM yO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trellix78 »</TD></TR><TR><TD CLASS="quote">While the suspension was lying on the ground, I chose to get Mugen hard rubber bushings. </TD></TR></TABLE>
Where can you find these? Which bushings does Mugen sell?
FRKWOO
Jan 15, 2011 06:47 PM
axels, axles, brakes, calculator, gsr, install, installing, integra, itr, jdm, mm, suspe, suspension, type, usdm
