How many Boosted miles on your high flow catalytic converter?
Just wondering, How many miles do you have on your cat with turbocharged setup. I got about 10K so far,
while n/a, high flow cat lasted about 40K and was half hollow on the inside.
searched to fine some answers again.. and looks like this is the only topic on this..
i'm at 18k boosted miles now with 2.5" carsound cat.. and i don't know when i should look into replacement.. i don't have any rattles, it runs fine as far as i can see.
I had a test pipe on my car then I kept getting check engine lights so I had to buy a High flow cat then found out that it was my map cen reading boost. I could tell a big difference in hp on the butt dyno so now that I have the map cen fixed with a better check valve I want to put my test pipe back on.
Audio28
Nov 16, 2002 03:38 PM
