Another VAFC problem...(yes I searched)
Old May 15, 2004 | 12:18 PM
JakeB.'s Avatar
Photography Pundit
Default Another VAFC problem...(yes I searched)
So I installed my VAFC today and I'm having a couple problems.
First, upon initial setup the voltage on all three sensors is 5.115V.
It is definately not incorrect wiring, I checked the wiring so many times I lost track.
I also had someone more experienced check the wiring for me.
After researching a little, I found that it wouldn't hurt to go ahead and start the car; which leads to the next problem.
Second, the throttle percentage does not move at all. It stays at a constant 100%.
This could be a result of the high voltage, but once again the wiring is correct.
I didn't check to see if vtec would engage because I didn't want to rev very high until tuning.
Also the cel shows map sensor fault when the VAFC is hooked up. When I bypass the VAFC on the Pressure line the cel goes away.
The VAFC is in my center console, under the armrest. I extended the wires using a little thicker wires than what comes with the unit. So, I was thinking this could be the problem (the continuity change). The only other thing I can think of is that the VAFC is bad.
Please help me out. Thanks in advance ~ Jake
Old May 15, 2004 | 02:36 PM
ShakesTheKlown's Avatar
Default Re: Another VAFC problem...(yes I searched) (MugenB18)
How did you connect all your wires? Tap splices, solder, wrap wires around each other? I used tap splices, and when I was doing my final check I noticed that one of the tap splices had let the ig power supply get away...
I'd say one of your grounds is not making good connection, but I don't know enough about electronics to stake my reputation on it. I know you probably did already, but are you sure that you put the brown and black grounds on right? Black closer to harness, brown closer to ecu?
Old May 15, 2004 | 04:34 PM
cajnatc's Avatar
Default Re: Another VAFC problem...(yes I searched) (ShakesTheKlown)
When I hooked mine up, I soldered all of the wires. I heard somewhere that you have to solder them. Just an idea.
Old May 16, 2004 | 01:08 AM
Default Re: Another VAFC problem...(yes I searched) (cajnatc)
The instructions don't say to solder them, just splice 'em...
Soldering is a good idea though. I think I'm going to go thru and redo mine. I went over a bump today and my RPM stopped displaying
Old May 16, 2004 | 04:32 AM
vtecsinan's Avatar
man this problem may also be from the operating system of your VAFC... request for an updated opretaing system...
or maybe two wiring instructions come with VAFC... the instruction manual book that shows it and a piece of paper that corrects the book... do the wiring from the paper man...
Old May 16, 2004 | 08:33 AM
JakeB.'s Avatar
Photography Pundit
Default Re: Another VAFC problem...(yes I searched) (vtecsinan)
All of the wires are soldered except the ones that are shown in the manual as being connected with the provided crimp connectors.
The Grounds are definately correct, and are soldered as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsinan &raquo;</TD></TR><TR><TD CLASS="quote">man this problem may also be from the operating system of your VAFC... request for an updated opretaing system...
I did download both the original and updated manuals from the apexi site, they matched the directions I already had. I will contact them about the possibility of an OS problem though, thanks for the input guys.
Any more ideas?
Old May 16, 2004 | 10:39 AM
v4lu3s's Avatar
RTFM
if throttle percentage is not changing it sounds like you are not wired onto the throttle signal wire.
if the map sensor is showing a fault you either got bad or incorrect wiring.
Old May 16, 2004 | 11:11 AM
JakeB.'s Avatar
Photography Pundit
Default Re: (v4lu3s)
ALL wiring is correct
Old May 17, 2004 | 06:22 AM
v4lu3s's Avatar
RTFM
tthen you got a defective vafc.
but it sounds to me like you know what you are doig? so why are you posting on here.
btw every SINGLE one of those that are brought into my shop with problems like yours....it was bad or incorrect wiring.
burntbinsd
Feb 20, 2007 03:53 AM
fireslinge
Aug 11, 2004 07:45 AM
JakeB.
May 16, 2004 09:03 AM
soundman
Aug 8, 2003 02:36 PM
JoshRambo
Jul 31, 2001 08:24 PM
