Need help finding wiring info for a JDM H22a into a 99 Civic SI
Ive already read the sticky post for the h22 info at the top of this page, but I havent found what I need. Ive basically found that there is a difference in wiring between the 96-98 (OBD2a) and a 99-00(OBD2b). I have a full prelude harness and a full 99 SI harness, but I need some info in making the SI harness work on the h22. Ive done an H22 swap in an EG before so Im not a newbie to wiring or anything. Do I need a resistor box for the injectors as well? Any help would be greatly appreciated. Thanks guys
Re: Need help finding wiring info for a JDM H22a into a 99 Civic SI (92tealTSI)
what year motor is ur h22? if its older.. as in 96 and before (i believe those are the right years..??) then yes u need a resistor box. but if its a newer one.. then the injectors should be saturated.. so u wont need a resistor box.
