Take a Look at my throttle cable is it OK? ---PLEASE LOOK
I just installed a STR manifold with a Ericks 68mm TB (GSR Spec)
The STR manifold doesnt has provisions for the Stock Throttle Cable bracket
I used a fabricated bracket along with the stock
Does it look ok??
Should i change it rigth away or drive around and see how she goes
The idle doesnt change and the TB reaches WOT with no problem
I heard a GSR throttle cable would be better is this true??
Please look and tell me what you think
The bottom pic is of a tee that i am planning to put in to get coolant over to the Icdle control valve on the STR manifold
Does that look like a good idea ??
Please go here
http://www.cleartaillights.com/testpage.htm http://www.cleartaillights.com/testpage.htm
HELP IS GREATLY APPERICATED
Does it look ok??
Please go here
Seems okay....you will be able to tell when you drive it how it is.....you might have some poopy throttle repsonse/feel
B18C5-EH2
Apr 12, 2005 02:32 PM
