Take a Look at my throttle cable is it OK? ---PLEASE LOOK
I just installed a STR manifold with a Ericks 68mm TB (GSR Spec)
The STR manifold doesnt has provisions for the Stock Throttle Cable bracket
I used a fabricated bracket along with the stock
Does it look ok??
Should i change it rigth away or drive around and see how she goes
The idle doesnt change and the TB reaches WOT with no problem
I heard a GSR throttle cable would be better is this true??
Please look and tell me what you think
The bottom pic is of a tee that i am planning to put in to get coolant over to the Icdle control valve on the STR manifold
Does that look like a good idea ??
Please go here
http://www.cleartaillights.com/testpage.htm http://www.cleartaillights.com/testpage.htm
Autoworks
Mar 10, 2005 04:19 PM
Ls1 FD3s
Jan 15, 2005 10:51 PM
NeXtLeVeL_TyPe_R
Nov 6, 2001 07:36 PM
