is there such a thing as 1000cc saturated injectors ? or am i stuck to get peak and hold?
Old May 15, 2004 | 12:36 AM
greenmonster's Avatar
Default is there such a thing as 1000cc saturated injectors ? or am i stuck to get peak and hold?
need 1000cc injectors , is 750cc the cap for saturated?
Old May 15, 2004 | 01:35 AM
LBR92DA-T's Avatar
750 is the biggest in saturated as of right now.. who knows.. rc might make bigger saturated.. as for 1000s you're stuck with p&h
Old May 15, 2004 | 09:52 AM
Rod.'s Avatar
Default Re: (LBR92DA-T)
750 is the highest(will support 400whp)
you have to use a resistor box for the 1000cc (peak and hold)
Old May 15, 2004 | 12:53 PM
Default Re: (redturbocivic)
ack thanks guys...you guys have a wiring diagram for a resistor box...
Old May 15, 2004 | 03:31 PM
danimal's Avatar
Default Re: (greenmonster)
i *think* that some of the subaru guys use http://www.powerenterpriseusa.net hi-z 850cc injectors... that's still not your 1000cc limit, but maybe they have something newer? they are located in irvine.
i don't know what the packaging constraints are, they don't list these as being available as drop-in injectors for hondas.
Old May 15, 2004 | 03:48 PM
danimal's Avatar
and here are the calcs and info for adding ballast resistors: http://members.shaw.ca/megasqu...esist
Old May 16, 2004 | 08:43 PM
LBR92DA-T's Avatar
i thought 750s can handle more than 400? according to atp they can handle about 500...
Old May 16, 2004 | 10:01 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenmonster &raquo;</TD></TR><TR><TD CLASS="quote">ack thanks guys...you guys have a wiring diagram for a resistor box...</TD></TR></TABLE>
Just wire it into your injector wire.
I power wire and 4 injector wires.
Your stock injectors just dump voltage to ground to open them, so it's real eay to install. wire it up.
BoostinTEG
Jan 22, 2011 06:34 AM
b16bri
Sep 5, 2010 02:53 PM
civicsaremean
Jun 29, 2007 06:17 AM
boost_is_best
Feb 28, 2006 03:45 PM
thid92
Aug 10, 2003 08:23 PM
