Fuel Pressure stuck on 50psi. Help
Guest
Posts: n/a
I have used 3 stock regulators.
I have used 3 different fuel gauges.
I have used 3 different b&m regulators
....Fuel pressue does not adjust! - Sits rich.
Anyone have a problem like this?
Any possible causes? - Clogged/pinched return line?
Thanks!
Thanks!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 »</TD></TR><TR><TD CLASS="quote">bump
whats the stock pressure at idle and at wot?</TD></TR></TABLE>
idle 49-50 WOT goes down to like 40
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">Could be you need a new fuel pump ...</TD></TR></TABLE>
No we used two different ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedymon »</TD></TR><TR><TD CLASS="quote">I thought fuel pressure was supposed to go up a little when on the throttle?</TD></TR></TABLE>
You're absolutely correct...
Pressure goes up as a function of manifold pressure, not solely as a function of rpm. You could rev the engine at a standstill and the pressure wouldn't increase....it might even decrease.
