Si Vortech supercharger owners, need advice on how to launch
All right i try to be as through as i can, and hopefully get some advice that i can put to use. The cars a 00si, vortech supercharged w/aftercooler @8psi, gsr cams, skunk2 cam gears, dc 4-1 header, dcTCI twin chamber exhaust, str 68mm tb, ACT flywheel, clutchnet Stage 3 clutch, vafc, running the fmu for now, hondata intake gasket,walboro255 pump. suspension: tokico illuminus w/tein stech springs, motor mount inserts, and at least 3 new motor mounts. tires: 15"rota slips w/205/50/15 falken azenis tires. Alright i been to the track twice since i put the SC on the car, making a total of about 10 runs. I know the car can do better but i cant get out of the 14s, but running over 100mph. I tried differant tire preasures but havent been able to find a sweet spot, any advice here? I have tried differant rpms to launch at, i either wheel hop real bad or bog out, either ones hurting my 60ft. Whats a good rpm to launch from? I know i can drive cause i have gotten 2.19 60fts when the car was NA, but its totally differant now and driving me nuts and i am getting aggrivated . Tomorrow i going to install the precsion 440cc injectors and tune it with the afc hack, until my hondatas installed and tuned. I guess the next thing i need to get jim fabs traction bars, or who else would you guys recommend? Please help, i am trying to get this car dialed in to run mid 13s, i know it can by the mph i just got to get it off the line right first. May 23 the import races at rockinghams going on and i want to run well. Were i go here, the tracks not the greatest, last 1/8miles is slightly uphill, and seems most time track conditons suck, rockingham should be better.
