i need to learn how to drive :(
Old Jan 7, 2004 | 05:57 AM
ITRswapandslow's Avatar
Default i need to learn how to drive :(
yeah, i suck at driving....
14.2@99....
2.5 60 ft..so much wheel hop, i got scared and let off as soon as i launched.
i had a loose motor mount...and it's busted. the hydraulic one of course.
car:
98 DX hatch
96 itr
exedy organic piece of **** on itr flywheel
an-r compact header
2.5" crush bent **** for exhaust (no cat)
aem 3" CAI
60psi FP
stock ecu..no add ons
running on 205/60 14 AVS ES100's (friend moutned them backwards..but doubt that affected it) tire pressure was anywhere from 18-15psi
urathane inserts
i'm going to order some Jimfab arms, side and rear mounts, get my other clutch in and flywheel, and run on some slicks....so i can get away from the devil wheel hop
also, i have yet to get on the dyno because of my job...and as soon as i do, in go the RLZ stage 2 cams, SRR cam gears, 255lph fuel pump, obd1 conversion, VAFC, and some tuning.
any ideas what this would run with a DECENT 60ft and some traction?
Old Jan 7, 2004 | 06:32 AM
see_our_vtec's Avatar
Default Re: i need to learn how to drive :( (ITRswapandslow)
first off
1. don't let your tire presure get below 20psi, if not 22psi.(unless using d/r's or slicks)
2.fix the motor mount.
3. what are you launching at
4. how are you launching(ie dump, slip etc.)
5. where are you shifting at
Old Jan 7, 2004 | 07:23 AM
1. after all the trying with the tires on several cars....18psi is the best, and 3 ppl have agreed to it unknowinly.
2.workin on it
3.anywhere from 4400-5800
4.slipping, dumping, anything
5.8800....i gained 2mph from moving my shift from 8500-8800
also, the clutch...it's a piece of ****. you slip it and it stops gripping all together. even a little bit of slipping on launch..and it was giving up. 6 puck unsprung on the way
Old Jan 7, 2004 | 08:29 AM
Default Re: (ITRswapandslow)
the reason i say don't go below 20-22psi is most radials i've seen "cup" the pavement and don't get a complete and perfect contact patch with the ground.
i'd start at 4600 with a slight slip and work my way up. you should at least be pulling 2.2's with your setup. the new clutch should help quite a bit though.
Old Jan 7, 2004 | 09:08 AM
myhatchrips's Avatar
with good driving and slicks you should run low to mid 13's. good luck
Old Jan 7, 2004 | 09:32 AM
b19coupe's Avatar
That mph would have you into the 13's no problem. I ran a 13.6 @ 98 mph last year with a 2.0 60'.
Old Jan 7, 2004 | 09:43 AM
MaxBoost's Avatar
New User
Default Re: i need to learn how to drive :( (b19coupe)
Mount the tires the right way! It does make a difference, and can be dangerous in the rain...
That clutch does suck
Fix those mounts!!! They are what's causing your wheel hop..
I ran a 13.91 with your mph with a 2.2 60ft on kumhos..
Old Jan 7, 2004 | 06:00 PM
Casey's Avatar
Default Re: i need to learn how to drive :( (MaxBoost)
let me drive it rob. i was pulling 2.1s on my avs 100s get a new clutch and stiffen the motor up, should make a huge difference
Old Jan 8, 2004 | 03:41 PM
JDogg's Avatar
Default Re: i need to learn how to drive :( (Casey)
yeah, rob sux at driving. we went back to the same track a week later with slicks and a fixed motor mount. guess what... exedy clutch cant do a burnout with slicks and he ran the same time with the slicks that he did on the street tires. 14.2 at 99mph..
Old Jan 8, 2004 | 03:43 PM
Casey's Avatar
Default Re: i need to learn how to drive :( (JDogg)
he told me, its still the driver, not the car
Old Jan 8, 2004 | 03:47 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">he told me, its still the driver, not the car </TD></TR></TABLE>
yeah, i dont think anyone can arque with that
Old Jan 8, 2004 | 06:32 PM
yeah, my clutch is a piece.....it burnt more than the tires
99gsvtec
Oct 19, 2009 07:07 AM
ghostsi69
May 15, 2004 05:17 AM
g2man
15
Jul 1, 2003 02:21 AM
MrSmith
Jan 22, 2002 04:23 PM
goern-R
Nov 12, 2001 12:35 PM
