D16 crank removal
Old May 14, 2004 | 06:24 PM
Aquafina's Avatar
Default D16 crank removal
I've gotten the main cap off and now I'm stumped on the two caps holding the crank in. TIA.
Old May 15, 2004 | 06:33 AM
Aquafina's Avatar
Default Re: D16 crank removal (Aquafina)
Anyone?
Old May 15, 2004 | 01:16 PM
Aquafina's Avatar
Anyone at all?
Old May 15, 2004 | 03:46 PM
hondateknician's Avatar
you said main cap...you only took one off? theres five....at one end of the crank is the oil pump and the other is the rear seal... is that what your refering too??????
Old May 15, 2004 | 07:01 PM
Aquafina's Avatar
Default Re: D16 crank removal (hondateknician)
There is only one main cap.
Old May 15, 2004 | 07:20 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">There is only one main cap.</TD></TR></TABLE>
eerrr... ?
Old May 15, 2004 | 07:31 PM
Aquafina's Avatar
Default Re: D16 crank removal (hybridvteceg)
Pull the oil pan off and look, there is one main cap. Take the bolts out, hit it with a rubber hammer, and pull it off. Now there are two things on the sides holding it on, how do I get them off?
Old May 15, 2004 | 07:36 PM
dfoxengr's Avatar
no there really are 5 of them.
Old May 15, 2004 | 08:08 PM
_BEN_'s Avatar
I know where you can dl the helms for a 92~95 civic and it will have all of the procedures for breaking down a d16z6. If you want it pm me.
Old May 15, 2004 | 08:47 PM
Aquafina's Avatar
Default Re: D16 crank removal (_BEN_)
One main cap, not 5.
Now can anyone tell me how to get the crank out?
Old May 15, 2004 | 09:05 PM
B20vtec86crx's Avatar
there are five caps.. each cap have two bolts going thru it,there is 1 oil galley on top /bottom of main caps.....
the two caps that you re stump on are main seals
you have to remove rear main seal housing and oil pump assembly on each end ..they are held by bunch of 10mm bolts.. good luck
Old May 15, 2004 | 09:42 PM
Default Re: D16 crank removal (B20vtec86crx)
lol....dont forget the hondabond....
Old May 16, 2004 | 12:59 PM
S9i1R's Avatar
there are 5 caps but they sometimes stick to the thing going across (not sure what it's called). but yea you'll need to pull the harmonic balancer/timing belt & gear/oil pump/main caps/rear seal. then it should drop out of there.
cordillera auto
Engine Machining & Assembly
Jun 16, 2019 11:51 AM
AnthraxVX
Aug 31, 2006 08:59 PM
Koble
Jan 6, 2006 10:17 PM
Greyout
Jun 27, 2003 01:31 PM
eddiecut
Apr 10, 2003 11:03 PM
