D16y8 n/a max numbers
Old May 14, 2004 | 06:21 PM
95civicSirCoupe's Avatar
Default D16y8 n/a max numbers
what is the highest any one has seen a n/a d16y8 push. I was wondering cause i want my newly swaped d16y8 in my 95coupe to hang with the local street posers with out the use of nos or forced induction.
Old May 14, 2004 | 06:27 PM
barto's Avatar
Default Re: D16y8 n/a max numbers (95civicSirCoupe)
i think the most ive heard of is 180 whp. ill see if i can find the source
Old May 16, 2004 | 08:57 PM
BMac86's Avatar
I was going this route too, I have all the mods that you have listed, plus a GSR TB, B&M FPR, AEM ITR cai, Comptech Header & Exhaust, and a Crower Stage2 cam and valvetrain to top it off. Thought about new pistons and such, but after a year of NA, I decided that I can make more power for prolly half the money with boost. But to answer your question, I saw I think 184whp on a guys b7 on here I think? It was a pure drag car though, not streetable. He ran super high compression with high test gas.
Old May 16, 2004 | 09:29 PM
Uncle Ben's Avatar
Default Re: D16y8 n/a max numbers (BMac86)
I've been checking this out also. I found this, to show me what to expect. Hope this helps you man. The 1/4 mile z6 thread. Not a y8, but basically the same thing.
Also, here's a great thread to answer some more questions. D-series.org forum
Modified by Uncle Ben at 6:59 AM 5/17/2004
Old May 16, 2004 | 09:31 PM
illicon2003
Guest
Posts: n/a
you might be able to get like 150 whp with 5 thousand bucks AHAHAHA
Old May 16, 2004 | 09:55 PM
Uncle Ben's Avatar
Default Re: D16y8 n/a max numbers (illicon2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicon2003 &raquo;</TD></TR><TR><TD CLASS="quote">you might be able to get like 150 whp with 5 thousand bucks AHAHAHA</TD></TR></TABLE>
Really, tell that to Wil, the owner of the Exospeed Crx...his thread
Old May 16, 2004 | 10:26 PM
blackeg's Avatar
Default Re: D16y8 n/a max numbers (Uncle Ben)
builthatch made 164whp i believe with an n/a d16y8
Old May 16, 2004 | 10:55 PM
Uncle Ben's Avatar
Default Re: D16y8 n/a max numbers (blackeg)
Not to thread jack, but as I said earlier, I'm also working on n/a z6. I've been reading around, and many people say a y8 manifold will help out alot, is this true? If so, how much? (Either this option, or spend 338 for the Skunk 2...)
Old May 16, 2004 | 11:41 PM
4dohs4mohoes's Avatar
you jacked my avatar. Looks like ill be the gentleman and change mine
Old May 17, 2004 | 12:46 AM
H22A EG6's Avatar
Default Re: D16y8 n/a max numbers (boo bees)
i would just go with the turbo simple and easy power
Old May 18, 2004 | 06:34 AM
barto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben &raquo;</TD></TR><TR><TD CLASS="quote">Not to thread jack, but as I said earlier, I'm also working on n/a z6. I've been reading around, and many people say a y8 manifold will help out alot, is this true? If so, how much? (Either this option, or spend 338 for the Skunk 2...)</TD></TR></TABLE>
if you are doing an n/a d-series you might as well get the best parts you can get to make things easier
jz2518
Mar 24, 2015 07:33 PM
drowzysleeper
Oct 16, 2005 05:49 PM
HksHaitian
May 3, 2005 07:03 PM
Tofu94
Jun 2, 2004 10:38 AM
