low compression results on cyl 1 and 2
Old May 14, 2004 | 05:49 PM
0554's Avatar
Default low compression results on cyl 1 and 2
my buddies first gen b16a goes 210,210,240,240 anyone know why those two cylinders would be that much less maybe bad valve seals? or rings?
Old May 14, 2004 | 06:24 PM
Lord Helmet's Avatar
Default Re: low compression results on cyl 1 and 2 (88crex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex &raquo;</TD></TR><TR><TD CLASS="quote">my buddies first gen b16a goes 210,210,240,240 anyone know why those two cylinders would be that much less maybe bad valve seals? or rings?</TD></TR></TABLE>
easy way of find out is to do a leakdown test. that will tell you if it's the valves seals, valves, or the rings. btw those #'s are within specs.
Old May 15, 2004 | 11:52 AM
Rod.'s Avatar
could be your rings, do the leakdown and find your real answer
Old May 19, 2004 | 10:00 PM
victoriasamantha's Avatar
i was told as long as they r within 20% they are ok
Old May 20, 2004 | 06:05 PM
0554's Avatar
yea thanks for the replies. i dont really care beings it not my car or motor.
1sikhatch
Apr 26, 2007 02:22 PM
.I.Need.Money.
Jul 5, 2006 05:35 PM
turbo95eg6
Jul 10, 2005 07:22 AM
ALLMOTOR18
Dec 27, 2003 07:54 AM
DANG YO
Nov 24, 2003 04:26 AM
