B16 with ITR internals, help please.
Old May 14, 2004 | 05:07 PM
libila's Avatar
Default B16 with ITR internals, help please.
I would like to know just a couple things. If I do a B16 swap into my Ef civic dx with ITR internals will I need to get special tuning done? If so, is there possibly a chip for the ECU that I can purchase to get around that? Also, what kind of power would an ITR built B16 put out roughly?
Im planning on the ITR pistons, rings, cams, and springs. Should I get the intake manifold as well? Since I have the motor out what else would be wise to replace (ex. water pump)? One last thing for now, will the ITR pistons fit the stock rods or do I need to get new rods? Thanks in advance guys
Old May 14, 2004 | 05:18 PM
Rick Solis's Avatar
Default Re: B16 with ITR internals, help please. (libila)
ITR pistons lower compression in a B16
Old May 14, 2004 | 05:19 PM
libila's Avatar
Really?
What would you suggest without going all out. Im looking for a little extra power out of the B16, nothing crazy.
How good is the bottom end on a B16? Maybe I should just do head work??
Old May 14, 2004 | 05:24 PM
Rick Solis's Avatar
Default Re: (libila)
CTR Pistons and a recomendation of knowledge... Thats really the best advice... Learn all you can, especially before you start buying parts...
Old May 14, 2004 | 05:31 PM
libila's Avatar
Yea Im still learning about hondas but Ive acquired alot of knowledge the past 3 days. Im not going to be buying anything for a couple months because I really want to have my mind set. Plus I am looking into the AWD conversion because I live in Tahoe. Ill keep searching but please, keep the comments coming.
Old May 14, 2004 | 05:38 PM
Rick Solis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by libila &raquo;</TD></TR><TR><TD CLASS="quote">AWD conversion</TD></TR></TABLE>
No
Old May 14, 2004 | 05:45 PM
S9i1R's Avatar
Default Re: (SoCalude98)
If i were u I'd get the CTR pistons and werk on the head ALOT that is where you'll get your performance mainly
Old May 15, 2004 | 12:12 AM
libila's Avatar
Why, its been done. (4wd conversion)
With CTR pistons, what would be a good rod to accomidate it? Can I get away with using the stock ones?
Old May 15, 2004 | 01:13 AM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by libila &raquo;</TD></TR><TR><TD CLASS="quote">Why, its been done. (4wd conversion)
With CTR pistons, what would be a good rod to accomidate it? Can I get away with using the stock ones?</TD></TR></TABLE>
yes use stock rods
they are press fit like your b16 rods
get new rings, do a lite hone
ITR cams, ITR intake manafold, ITR throttle body, and a decent header with a 2.5" collector
Old May 15, 2004 | 10:44 AM
libila's Avatar
Sounds good! Ill do more research but just curious, about how much hp/tq is that?
I want the car to be quiet as well. What kind of exhaust is really not that noticable and quiet? Of course Ill have the cat in there as well but its really important to me to not have a loud, annoying exhaust. Thanks in advance.
Old May 15, 2004 | 01:28 PM
libila's Avatar
Where is a good place, price wise, for CTR pistons? How much of a bore would be wise to get?
Old May 15, 2004 | 01:57 PM
duckmanEG's Avatar
Sexy Cheese Cake
heeltoe has them and i would go with the oversized ones, i think its like 81.25 (300 with rings), get a 2 layer headgasket( can make ur self with oem one), get portflow inners and itr outers springs (200) , aebs intake manifold (145), bored tb from a guy in this site (100) , then sum used stage 2 rlz cams (500ish/600 new), and a good header with a 2.5 collector with 2.5 piping and i think ull be set. also i would think about oem itr lsd (400ish for complete swap) let me tell u its a difference my friends jdm b16a with just i/h/e beats itr's from the line and top end they help, for exhaust also get a long resonator.
Old May 15, 2004 | 04:45 PM
libila's Avatar
I have about 3 weeks to make up my mind. When the motor gets here Ill probably just do the regular maintance on it then install it. If I feel it needs to be quicker Ill do the ITR top end work, TB, intake mani, then i/h/e.
When I order the motor I plan on getting a tranny with a LSD. Im going to order the motor from hmotors. Ive been reading good things about them. Im going to opt for the LSD tranny, hasport mounts, linkage, and A/C bracket. Will I need the 90-93 integra steering knuckles and hubs?
Old May 15, 2004 | 06:55 PM
spaceman's Avatar
awd=not good idea
Old May 15, 2004 | 11:30 PM
libila's Avatar
Ok we have established that, its not a big deal. I do however need to know if I will need the 90-93 integra steering knuckles and hubs.
Old May 16, 2004 | 06:09 AM
hotintegranights's Avatar
no
Old May 16, 2004 | 01:08 PM
S9i1R's Avatar
Default Re: (irev210)
if you get the ITR cams I'd recommend getting the ITR or GSR lost motion assembly other wise you could break your cams
Old May 16, 2004 | 03:33 PM
krazie1's Avatar
BANNED
Default Re: (S9i1R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R &raquo;</TD></TR><TR><TD CLASS="quote">if you get the ITR cams I'd recommend getting the ITR or GSR lost motion assembly other wise you could break your cams</TD></TR></TABLE>
not really but it is best to do so
as this motor is what 14 years old or so
and well b16 1st gen have the problem of going out
u will know by the annoying ticking noise and it ain't ur valves
and well I would think or tell u to yes get the 90-93 changeover as well u have a bigger motor not a dinky single cam 1.5 in there so u kinda got to figure well more power requires more stopping power
just my opinion but u can do without it
or at least try to upgrade ur M/C and prop valve
dc2gsr96
65
May 26, 2006 01:52 PM
turbo_hatch93
May 21, 2006 11:02 PM
mrDFWmechanic
Aug 1, 2005 10:32 PM
VtecDA9
Jun 2, 2003 07:35 AM
done
Aug 1, 2002 09:42 PM
