D16Y8 turbo or K20A2/A3 hatch
Old May 14, 2004 | 05:03 PM
Import Al's Avatar
Default D16Y8 turbo or K20A2/A3 hatch
Here's the deal. I am seeing some rust-free EF hatches around here for about 2k. But before I buy one, I want some views on which one YOU'D build. Like which year would be best and light for a daily driver/drag car. Here are my goals. 1. QUICK: atleast Low 13's, a mid-range monster w/ decent top-end . 2. MPG: 91 octane costs $2.55 here in CA, and I drive quite a bit, so the Y8-T probably wins here. 3. RELIABILITY: I don't like to change head gaskets every 3 months. Which motor would survive longer? I'm asking you guys because you know what I heard on D-Series.Org. Both are awesome motors, but the K20 is like 5g+ and I've heard kinda hard to transplant into a 4th gen. I am kinda leaning towards the D project, but there's something about 6 gears... I have a friend who works with tuners so labor $ won't kill me. I'd like to hear both sides here, so Speak Up sheepish K people!!
Modified by Import Al at 12:17 AM 5/18/2004
Old May 14, 2004 | 05:09 PM
96-EJ6 B18C's Avatar
Default Re: D16Y8 turbo or K20A2/A3 hatch (Import Al)
Boosted D-series...the K isn't at all practical.
Old May 14, 2004 | 05:21 PM
I3ackfire's Avatar
Default Re: D16Y8 turbo or K20A2/A3 hatch (96-EJ6 B18C)
Y8 Turbo
Old May 14, 2004 | 06:38 PM
sporkcrx's Avatar
If I had the money, it would be the K series without a thought! Six speed! Tons of potential! Hello! Just buy a beater and put a y8 turbo in that, it doesn't cost much at all
Import Al's Avatar
Default Re: D16Y8 turbo or K20A2/A3 hatch (I3ackfire)
OK. I like the Y8 cuz if you blow it to shrapnel, it'll only set you back like 400 bucks! But anyone here have some pros for the K20? I mean, it can hit 200whp w/ bolt ons, right? I might be able to find a SI or base RSX front clip for less than 5g, but it won't have 178whp, and aftermarket K parts are the most expensive fwd honda engines to work on...
Old May 14, 2004 | 07:15 PM
d16singlecammer's Avatar
If I was in your shoes ill just get a d16y8 because, 1. easier swap 2. cheaper to replace 3. more parts are available and 4. CHEAPER Well for the year or model to look for anything 88 is good, unless if its an 89 HF. Just keep away from bulky Si models or if you want the sunroof and door mounted seat belts found in 89-91 models go for it. Good luck
Old May 14, 2004 | 08:33 PM
The ZC's Avatar
Default Re: D16Y8 turbo or K20A2/A3 hatch (d15singlecammer)
Sombody needs to swap an odessy motor in. That would be sick as hell.
Dave
Old May 14, 2004 | 09:33 PM
cbrodac0424's Avatar
listen to 96-ej6 b18c he knows his stuff and take a look at his car that his shop is building nice
Old May 14, 2004 | 09:34 PM
Dibble's Avatar
http://www.hybrid-racing.com/
Very nice people.
Talk to them.
Old May 14, 2004 | 09:44 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (Dibble)
K-series ownz!
Old May 14, 2004 | 09:55 PM
oldB18EF's Avatar
Default Re: (HybridHatch88)
K series would be the way to go but it would be a bitch with mounts since i dont think they are availiable for the EF
Old May 15, 2004 | 02:54 PM
d16X's Avatar
I would do the K-series if you have the money to
Old May 16, 2004 | 06:32 PM
Import Al's Avatar
Default Re: (d16X)
Some of you know your Honda. What kinda gas mileage would a K20A2 or A3 get in a 1900 lb. car? How hard are K's to maintain? If I got almost 30 per gal on premo, I'd save and swap the 2.0L, Hondas survive NA. Would I have mid-range and any TQ with a NA K? Top speed=Never use...Love guts though.
Old May 16, 2004 | 06:35 PM
Import Al's Avatar
Default Re: (Import Al)
Bump for Repl;es!!
Old May 17, 2004 | 12:00 AM
91civicDXdude's Avatar
hmmm....
$5-6k for 160-200hp for a k20
or
spend that same amount or a little less on the y8, building up the entire engine and a nice turbo kit.
with $5,000 to spend, you can *easily* pull 300hp out of a d series; there are people out there making over 200whp with a $500 junkyard turbo kit, and since its built from the bottom up, its going to be reliable.
Old May 17, 2004 | 12:28 AM
Jonathan_ED3's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">hmmm....
$5-6k for 160-200hp for a k20</TD></TR></TABLE>
For just the motor. Then you gotta worry about mounts, axles, wiring, custom hood etc... K series still isn't very practical in an EF; I'm not sure it will ever be.
Old May 17, 2004 | 04:55 AM
5litereater's Avatar
Default Re: (Jonathan_EH)
crx hf (lightest) + d series turbo = faster than k
not talking **** on the k tho. it would be more original than a dseries turbo hatch/crx.
Old May 17, 2004 | 07:13 AM
deftones0817's Avatar
Default Re: (5litereater)
I would say just a d16y8 with some bolt ons it would feel pretty fast but no where near what you want i guess...you would get the gas mileage you wanted though. One question have you thought about an h22a? I know you didnt list it but it could net you 13s and still get ok gas mileage
DEF
Old May 17, 2004 | 03:17 PM
Import Al's Avatar
Default Re: (deftones0817)
Yeah, def I thought about the whole Honda arsenal. Like B18b turbo, JDM b16 sir, B18c5, H22... But I narrowed it down to the K and D because they are light enuf to not F'up the weight balance and can pull off decent mileage too if built right. I am pretty settled on the Y8 now, thanks for the knowledge.
Old May 17, 2004 | 04:10 PM
HamiltonRex's Avatar
boosted D series
Old May 17, 2004 | 04:54 PM
Creepshow S60's Avatar
well for the price of a k20, you could build a badass boosted motor and still have some money left over....
-cody
Old May 17, 2004 | 05:35 PM
altoid's Avatar
correct me if im wrong here but you can't have a turbo on a car in cali unless it carb legal an nitrous is illegal too, so what are your plans around inspection time?
Old May 17, 2004 | 09:21 PM
Import Al's Avatar
Default Re: D16Y8 turbo or K20A2/A3 hatch (altoid)
Well, that's a good point. In my county, you only have to get it smogged every 2 years, so I'd do a custom turbo setup and give the inspector a $100 thank you. I know I can pass the sniffer, but unless you get a Greddy carb legal kit, it can't legally pass the visual test. Maybe the Greddy is a good kit after all.
Devon Watson
Jul 3, 2019 06:35 AM
Shelton
Northwest (Sales)
Jul 20, 2010 11:14 AM
brios86
Feb 4, 2009 10:29 AM
icefirezero
Jun 16, 2004 02:04 AM
Tofu94
Jun 2, 2004 03:29 PM
