Difference between USDM & JDM ITR Pistons
I just want to know the difference between the two, because the JDM yeild a slighty higher compression, why is it?
DO they have a higher dome?
Why are they bothed class as P73 then, if they are differnet? How would you beable to tell.
How mnay more degree's bigger are they then the USDM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire »</TD></TR><TR><TD CLASS="quote">Why are they bothed class as P73 then, if they are differnet? How would you beable to tell.
How mnay more degree's bigger are they then the USDM?</TD></TR></TABLE>
well the JDM P73 piston's part number is: P73-00
US P73 is: P73-A0 ("a" I assume = american)
Dunno the actual heighth specs but these images help show the differences.
JDM ITR piston (P73-00)...
US ITR Piston (P73-A0)..
Perfect that is what I was looking for!
So the bigger dome raises compression. How big of a compression difference is there between the 2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire »</TD></TR><TR><TD CLASS="quote">Perfect that is what I was looking for!
So the bigger dome raises compression. How big of a compression difference is there between the 2?</TD></TR></TABLE>
well US ITR engines are rated at 10.6cr, JDM ITR is rated at 11.0cr, so approx. .5 points higher w/an ITR piston.
Okay, Another question. Is it a good idea to use pistons that were previously used before, or can you buy after market ones, and if so who do you recommend.
I apprecciate all the help Katman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>**** its crazy how that hairline difference in size will make a difference in performance
gulftiresinc
13
Sep 5, 2004 02:59 PM
iH8RICERZ
Nov 14, 2002 01:25 AM
