??? Front lower control arm changing rear part with sway bar hole.?
Old May 14, 2004 | 10:54 AM
DerangedEG's Avatar
Default ??? Front lower control arm changing rear part with sway bar hole.?
Has anyone ever split the front lower control arm at the 2 bolts and replaced just the rear portion with sway bar mount hole. By that I mean the same ball joint to frame part is a civic DX but the back or rear of the lower control arm is changed to an EX to allow the front sway bar to attach. Anyone do this.?
Old May 14, 2004 | 11:01 AM
DerangedEG's Avatar
Default Re: ??? Front lower control arm changing rear part with sway bar hole.? (DerangedEG)
https://honda-tech.com/zerothread?id=856126
Here is a diagram of the front LCA 2nd post. The part I am talking about removing is part 1 2 from the rear portion that goes into number 3. The 2 bolts can be removed from part 1 2 to allow the rear portion that goes into 3 to be replaced and allow a front sway bar.
Old May 14, 2004 | 11:32 AM
moto27cm's Avatar
Yes. No problem. EX,Si,GSRs will bolt right up, maybe more.
Old May 14, 2004 | 11:48 AM
DerangedEG's Avatar
Default Re: (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm &raquo;</TD></TR><TR><TD CLASS="quote">Yes. No problem. EX,Si,GSRs will bolt right up, maybe more.</TD></TR></TABLE>
Cool that's what I was hoping...thanks.
boosteddb1_808
Aug 29, 2010 03:07 PM
08rampage
Jan 31, 2009 05:38 PM
vegaskurt
Jun 30, 2005 09:55 AM
Tyson
Sep 26, 2003 04:26 PM
