aftermarket regulator and vortech fmu
Old May 14, 2004 | 10:39 AM
silver4's Avatar
Default aftermarket regulator and vortech fmu
will a vortech fmu work with an aftermarket adjustable fuel regulator.?
Old May 14, 2004 | 10:42 AM
TRE_'s Avatar
Default Re: aftermarket regulator and vortech fmu (silver4)
yes.
Old May 14, 2004 | 11:09 AM
silver4's Avatar
Default Re: aftermarket regulator and vortech fmu (THE_HX)
how would you set it up?
Old May 14, 2004 | 11:11 AM
silver4's Avatar
what i mean is how what would you set the regulator on because if the fmu says add more but the regulator is set at 50psi then it wont go past that right and if you set it at 70psi then it stays that way all the time and you run too rich unless your on it.
Old May 14, 2004 | 11:34 AM
Griffin@Camtech's Avatar
just like you would on a stock regulator. everything is still the same
98GSR-Turbo
Dec 18, 2007 07:40 PM
joshfish79
Mar 6, 2007 09:59 PM
petarr
Sep 11, 2005 02:07 PM
ITR1071
Jul 5, 2002 12:45 AM
b18tdelsol
May 10, 2002 11:28 AM
