mini me, always off by 1/2 tooth?
Guys I've been reading and doing research and it seems like no matter what timing belt I use I'm going to be off by 1/2 tooth or something like that.
this happens when u use the z6 timing belt too? Or only when I use the stock timing belt then I need an adjustable cam gear with 5 degree advance.
Need help asap.
Need help asap.
yep, I would recommend adj cam gear , you may be able to compensate by adjusting the dist,. but you will have very limited tuning afterward. Not a good comprimise.
heres mine, so far mine is out about 4-5 deg also.
Edit: forgot 2 mention mine is a d16a6 block and a y8 head mini me combo
i don't believe the timing belt is the concern as youre supposed to use the belt that matches the head in most cases. Although, this guy just proved different combos work too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplypinoyy »</TD></TR><TR><TD CLASS="quote">i had no problem what soever....b7 block with a y8 head and z6 timing belt....both lower and upper timing marks liney up perfectly.</TD></TR></TABLE>
I'm sorry to say but I subscribed to the easiest mini me combo I've ever heard of, the a6 block y8 head setup hoping it would be easy. So far it s ok.
All I can say is make sure you use a timing gun, if you don't know how find someone who does
thatseemslegit
42
Sep 17, 2015 09:07 PM
EARLdaSQUIRREL
May 7, 2009 02:14 PM
JDMs1eeper
Aug 15, 2003 10:52 AM
