tubular manifold vs log style. facts?
Old May 14, 2004 | 04:57 AM
wolfsburg2's Avatar
Default tubular manifold vs log style. facts?
please help me out. i am a bit ignorant in this regard. what are the benefits of each. which is ultimately better for max hp. downsides of each? i tried to search to no avail
Old May 14, 2004 | 05:54 AM
FwdCivicHatch's Avatar
Default Re: tubular manifold vs log style. facts? (wolfsburg2)
The log manifold is limited when using high BOOST/HP setups, alot of people get boost creep, and the exhaust runners are not the same length. That allows the exhaust gasses to pressure the turbine altogether, and not in the pulses of pressure in which is optimal. Tubular/ Equal Length manifolds usually flow better, and allow a more constant flow of pressure on the turbine blades. And the wastegate is usually place in the collector which helps to prevent boost creep also....
Old May 14, 2004 | 05:58 AM
MiraiZ's Avatar
Most tubes don't allow you to keep your A/C whereas most logs do.
Old May 14, 2004 | 06:31 AM
TwoK4drSi's Avatar
Default Re: tubular manifold vs log style. facts? (MiraiZ)
Tubes are gonna run hotter due to amount of metal used so be prepared to have a hot engine bay. Logs do not run that hot
PS. I still have ac and powersteering with my tubes
DerekHollister
Oct 4, 2016 06:17 PM
mikej94civex
Jan 31, 2010 08:56 AM
Powelly
May 4, 2009 02:32 AM
BoostedH23a1
Dec 3, 2002 07:04 PM
