Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
RSR Down Springs
Old May 13, 2004 | 09:55 PM
prostreetonline's Avatar
Default RSR Down Springs
The flagship of the RS-R spring line is the Down spring. Designed to provide the best combination in looks, feel, and performance, the Down springs were engineered with a 30 to 50 % spring rate increase and efficient lowering stance. All this in combination is to achieve maximum maneuverability, surpassing stability in straight line driving and excellent cornering performance for the ultimate driving experience.
Properly lowering a car should provide looks, performance, and feel. The RS*R Down Spring is a lowering spring which meets all of these requirements. The RS*R Down Spring is made from SUP7N, a high quality material second only to the material found in the Ti2000. Made with the same, unparalleled manufacturing process as the Ti2000, the RS*R Down Spring provides the balance that every performance enthusiast is looking for: a comfortable ride, improved handling and a lowered vehicle stance.
Down Spring Vehicle Application and Specifications Guide
Application Drop Spring Rate Part #
Acura Front (in) Rear (in) Front (lb) Rear (lb)
Acura Integra 90-93 1.6 0.8 335 173 30-H010
Acura Integra 94-99 1.4 0.8 242 173 30-H020
Acura RSX Type-S 1.6 1.8 225 408 30-H030
Honda
Civic 89-91/CRX 2.2 1.6 279 218 30-H101
Civic 92-00 1.6 1.0 242 168 30-H110
Civic 01+ 1.6 1.6 154 364 30-H130
Accord 90-93 1.6 1.0 285 156 30-H200
Accord 94-97 1.8 1.6 285 156 30-H210
Prelude 92-96 Vtec/ 97-01 1.4 1.4 335 174 30-H300
S2000 0.8 1.4 262 332 30-H500
Infiniti
G35 Coupe 1.0 1.2 315 315 30-N400
Lexus
IS300 00+ 1.4 1.2 279 239 30-T400
Mazda
Miata 90-98 1.4 1.2 196 140 30-M010
Miata 99-00 1.4 1.2 196 140 30-M020
RX-7 88-91 Turbo 1.4 0.8 201 123 30-M100
Rx-7 93-95 0.8 0.6 349 261 30-M110
Mitsubishi
Eclipse 95-99 GST 1.2 0.8 319 179 30-B021
Evo VIII 1.4 0.8 246 325 30-B100
Nissan
240SX 89-94 1.6 1.2 168 168 30-N010
240SX 95-99 1.0 0.6 212 168 30-N020
300ZX 91-96 0.8 0.6 193 180 30-N100
350Z 02+ 0.6 0.6 345 417 30-N200
Scion
xB 2.0 1.2 137 141 30-T500
xA 1.8 1.6 157 161 30-T510
Subaru
Impreza WRX 02-03 1.8 1.2 216 177 30-F010
Toyota
Celica 00+ 1.6 2.2 178 226 30-T110
MR2 91-95 0.8 1.0 176 279 30-T200
MRS 01+ 1.2 1.0 94 153 30-T210
Supra 87-92 1.2 0.8 503 262 30-T300
Supra 93-97 Turbo 1.6 1.0 465 235 30-T311
For our pricing click here:
http://www.prostreetonline.com...rings
Other specials:
http://www.prostreetonline.com...h.asp
Old May 14, 2004 | 04:35 PM
rhetorical's Avatar
Honda
^^^how much do those lower the CRX?
Old May 14, 2004 | 06:28 PM
2.2 inches in the front, 1.6 in the rear.
Spring rates are 279 front, 218 rear
Thanks!
SLIKKCHICK
Jul 14, 2006 03:39 PM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
Stag 2000
Honda S2000
12
Feb 20, 2003 07:41 PM
