Modifying Motor mounts
Old Nov 6, 2001 | 10:46 AM
civicgsr's Avatar
Default Modifying Motor mounts
I wanted to share my experience with making home made poly urethane motor mounts.
Check it out: http://importnut.net/motormount.htm
as I pointed out on this page, this trick worked out really well and is definitely a nice low budget mod.
-Alex
Old Nov 6, 2001 | 11:00 AM
MrBite's Avatar
Default Re: Modifying Motor mounts (civicgsr)
Wow that really carries the whole weight of the engine/force of a hard launch? I'm not sure what window weld is so it looks like caulk to me Awesome though, I'm always looking for budget mods to do
Old Nov 6, 2001 | 11:28 AM
civicgsr's Avatar
Default Re: Modifying Motor mounts (MrBite)
Those torque mounts do not carry the weight of the engine. Just the force of the engine torquing over. For example, I was able to take them out without supporting the engine.
Window weld is what any auto/body shop would use to install windows on vehicles. You can find it at most autoparts stores and shops that carry body shop supplies.
-Alex
Old Nov 6, 2001 | 05:16 PM
speedworks's Avatar
try Lord(fusor) 123 seam catalized seam sealer in your mounts. 20 times better than window weld. can be purchased from autobody supply stores
Old Nov 7, 2001 | 05:57 AM
civicgsr's Avatar
Default Re: Modifying Motor mounts (speedworks)
I'll have to check that out.
Thanks
Shaynepolevault
Aug 22, 2008 04:59 AM
Streetballer4888
Honda Civic (2001 - 2005)
Apr 26, 2007 01:34 PM
Bevenue
13
Mar 1, 2007 01:36 PM
DFWRSXS
Jan 20, 2006 02:11 PM
NCSTIdriver
Sep 24, 2003 07:18 PM
