attention motor building gurus...
Old May 13, 2004 | 06:49 PM
hatchback_al's Avatar
Default attention motor building gurus...
hey there, i need to put a new block in my car. i currently have a d16y8 and would like to keep it to about the same motor compression wise, among other things. my cylinder head is good so im keeping that. i can get my hands on a y8 crank, pistons, and rods. my question is, will the crank, rods, pistons, and waterpump all fit in any d15 or d16 block? say a d15b7 block, will all those internals plus waterpump and oilpump from my y8 install right in? which motor do i buy bearings and rings for? the y8 or the b7? thanks.
Old May 13, 2004 | 07:37 PM
Default Re: attention motor building gurus... (hatchback_al)
bump
Old May 14, 2004 | 09:08 AM
anything?
Old May 14, 2004 | 09:11 AM
T S R Performance's Avatar
it should fit in a d16 block but im not too sure about the d15. if it does fit in the d15 youll probably have some nice compression if anything
Old May 14, 2004 | 09:47 AM
OptimusPrimeX's Avatar
Default Re: attention motor building gurus... (JRSCSingleSlamBeeTec)
dont quote me on this, but i dont think the D16y8's internals will fit D15b's.?.. You can slap those y8 internals in a y7 with lower compression.
But if you cant find anything here, .. go to http://www.D-series.org and do a search
Old May 16, 2004 | 11:48 AM
Default Re: attention motor building gurus... (OptimusPrimeX)
anyone have any idea if they will fit in all the d16 blocks?
Old May 16, 2004 | 11:54 AM
infinatenexus's Avatar
All D-16 internal parts are interchangeable, the crank, and pistons arn't interchangeable with the D-15
Old May 16, 2004 | 02:23 PM
Default Re: (infinatenexus)
k thanks
Txdragon
Engine Machining & Assembly
14
Feb 10, 2018 04:53 AM
AgentJam
15
Feb 6, 2016 02:47 PM
adammilad
May 17, 2010 08:25 AM
shadhman
Jul 8, 2008 12:22 PM
98civicEX
Dec 19, 2002 02:44 PM
