Need Help with car ALARM !!!! FAST
I have this alarm problem , first the alarm was installed by the pervious owner and i had be given only 1 remote , its for keyless entry too. This remote broke ( not fixable ). Today i was doing a tune up and the distributor and rotor and my friend noticed that there was a lose battery terminal so he pulled it.
The problem is i cant start the car , i cant crank it or anything and i cant disable the alarm system.
i see all the internal light flashing but nothing happened when i try to turn it over . How do i disable the alarm system so i can take it into a shop and get in fixed or replace with another alarm system
my suggestion is to go underneath the dash and try to undo all the wiring connected to the alarm system, especially the unit. You can probably find it somewhere in the mess of wires in there. good luck.
Everything is on tight , i think its the stock alarm system for a 92 si 4ws model , cause the red light over the stearing wheel is blinking .
How do i remove it ?
any simple ways of getting it removed and car started
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tintin11 »</TD></TR><TR><TD CLASS="quote">Everything is on tight , i think its the stock alarm system for a 92 si 4ws model , cause the red light over the stearing wheel is blinking .
any simple ways of getting it removed and car started </TD></TR></TABLE>
if its the stock alarm you should be able to start the car, just not use the radio unless you enter the 4 digit password.
EMILYKHAMPOU
Audio / Security / Video
17
Dec 21, 2014 09:15 AM
cambodia got civics too
Nov 5, 2005 05:21 PM
